2162787_en-US
2162787_en-US
2162787_en-US
tooltip trouble of s32ds 3.6.3
hello, experts.
i met a problem when i peripheral registers view in s32ds v3.6.3.  The view is docked on the right of the main view and the with is a little narrow. when the cursor is over a register name, the tooltip appears and just under the cursor, then view can not be scrolled. i have to move my cursor and then scroll again. i think the tooptip got the focus at that time. is there any solution?
best regards!
hi  jiri_kral,
my issue is that when the tooltip appeared, the view can not be scrolled.
Re: tooltip trouble of s32ds 3.6.3
sorry for delay. You can simply make the view wider or drag and drop the Peripheral registers tab to better place - for example down next debug console.
If there is some strange settings in debug perspective - reset the perspective. Window -> Perspective -> Reset Perspective.
I tested it with S32DS v6.4 and tooltip works as expected:
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-21-2025 12:13 AM
更新者:
