while testing the MCUboot fork from NXP, I noticed that in the September preview release a useful feature has been removed.
Specifically, I am referring to the support for three-slot mode with Encrypted XIP (two staging slots + one execution slot, used to enable revert).
I saw this commit:
7c455cf2d
with the message:
[MCUX-80671] Encrypted XIP: remove customization for three slot modeCould you please explain why this functionality was removed?
This feature was quite valuable for our use case, and understanding the rationale behind its removal will help us plan the next steps.
Thank you in advance for your clarification.
best regards
Max
Hi @mastupristi,
Three slot mode was a modification of the MCUboot code to support the revert mechanism (known from SWAP/DIRECT-XIP mode) in Encrypted XIP mode. However, on some devices, it's possible to implement DIRECT-XIP with flash remap and Encrypted XIP, so three slot mode doesn't make sense there. Additionally, due to the custom modification, it was difficult to maintain with newer MCUboot updates from the community, plus there were concerns about eventual certification, etc.
We are not planning to reintroduce it again.
BR,
Edwin.
Hi @mastupristi,
I will investigate this topic internally. Could you please provide the MCU that you are currently using?
