Does anyone have an explanation for the exception on the part number above. We require MPC8308CVMAGDA, however the parts received are marked with SPC8308CVMAFDA, AF part number ending indicates 333Mhz but the required part number denotes 400Mhz. The device also has an addition 'M' marking in the top right corner which i haven't see previously, has this been added as part of the exception? Will the part have the same functionality?
I have attached a photo of the device and the label received.
You can ask the supplier if they have COC certificate. Only the supplier with COC certificate is the real original supplier.
You bought a fake product. Return it immediately.
This is a scam.
hi,
We have the same scenario. How did you move forward in your case?. Did NXP confirm that MPC8308CVMAGDA and SPC8308CVMAFDA are identical?
Thank you.
