I am using a Wi-Fi module manufactured by u-blox, which integrates the NXP IW416 chip.
The current firmware in use is sdiouartiw416_combo_v0.bin.
I would like to know:
- Does this firmware support Wi-Fi Protected Setup (WPS), specifically the Push Button method?
- If not, is there any alternative firmware for WPS support?
Thank you for your support.
Hello, @Christine_Li .
I understand. Thank you very much for taking the time to check.
If I have additional questions, I may ask you again.
Thank you in advance for your continued assistance.
nn3.
Hi, @nn3
Thanks for your reply.
For 1:Yes, it supports WPS on L6.6.3's release.
For 2: You can download L6.12.20 release doc through below link, and for Wi-Fi, the Release Note file name is:RN00104_NXP_Wireless_SoC_Features_and_Release_Notes_for_Linux.pdf after you unzip it.
https://www.nxp.com/docs/en/supporting-information/LF6.12.20_2.0.0-Docs.zip
Please let me know whether have any other concerns on this case.
Christine.
I really appreciate your thoughtful reply.
May I ask the following additional questions?
・Also, could you tell me if sdiouartiw416_combo_v0.bin. (L6.6.3) supports WPS connection?
・Is there a way to check the latest release note of L6.12.20?
I am sorry to bother you , but I appreciate your assistance.
nn3.
If still need any help or have any concerns on this case, please do not hesitate to let me know or create a new case to us.
Christine.
Hi, @nn3
Thanks for creating case to us.
Yes, IW416 combo FW: sdiouartiw416_combo_v0.bin. supports Wi-Fi Protected Setup (WPS), specifically the Push Button method.
I checked the latest release note of L6.12.20, please see below screenshot for your reference.
Christine.
