2148184_zh-CN
2148184_zh-CN
2148184_zh-CN
适用于 imx8mm 主板上的 ar0144 摄像头的恩智浦 6.6.36 内核用于捕获图像或视频
@joanxie
GST_DEBUG=3 gst-用上市-1.0-v\
v4l2src num-buffers=$number_of_PIC device=$vid_device=$vid_device!\
video/x-raw,format=GRAY8,depth=8,$FRAME_SIZE !\
videoconvert !\
jpegenc !\
issue is
Starting GStreamer pipeline...
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Pipeline is PREROLLED ...
将管道设置为正在播放 ...
0:00:00.244283375 784 0xffffb4000b70 WARN v4l2 gstv4l2object.c:5023:gst_v4l2_object_get_crop_rect:使用 VIDIOC_G_SELECTION 获取默认裁剪矩形失败:参数无效
0:00:00.244416875 784 0xffffb4000b70 WARN v4l2 gstv4l2object.c:5230:gst_v4l2_object_probe_caps:使用 VIDIOC_CROPCAP 探测像素宽高比失败:参数无效
新时钟:GstSystemClock
0:00:00.246845250 784 0xffffb4000b70 WARN v4l2 gstv4l2object.c:5023:gst_v4l2_object_get_crop_rect:使用 VIDIOC_G_SELECTION 获取默认裁剪矩形失败:参数无效
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0。GstPad:src: caps = video/x-raw, format=(string)GRAY8, depth=(int)8, width=(int)1280, height=(int)800, framerate=(fraction)120/1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, format=(string)GRAY8, depth=(int)8, width=(int)1280, height=(int)800, framerate=(fraction)120/1, interlace-mode=(string)progressie
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:src: caps = video/x-raw, format=(string)GRAY8, depth=(int)8, width=(int)1280, height=(int)800, framerate=(fraction)120/1, interlace-mode=(string)progre
/GstPipeline:pipeline0/GstJpegEnc:jpegenc0.GstPad:sink:caps = video/x-raw,format=(string)GRAY8,depth=(int)8,width=(int)1280,height=(int)800,framerate=(fraction)120/1,interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0。GstPad:sink: caps = video/x-raw, format=(string)GRAY8, depth=(int)8, width=(int)1280, height=(int)800, framerate=(fraction)120/1, interlace-mode=(string)proge
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, format=(string)GRAY8, depth=(int)8, width=(int)1280, height=(int)800, framerate=(fraction)120/1, interlace-mode=(string)progresse
0:00:00.253795500 784 0xffffb4000b70 WARN v4l2 gstv4l2object.c:5023:gst_v4l2_object_get_crop_rect:使用 VIDIOC_G_SELECTION 获取默认裁剪矩形失败:参数无效
0:00:00.253877250 784 0xffffb4000b70 WARN v4l2 gstv4l2object.c:5023:gst_v4l2_object_get_crop_rect:使用 VIDIOC_G_SELECTION 获取默认裁剪矩形失败:参数无效
0:00:00.259326750 784 0xffffb4000b70 ERROR v4l2bufferpool gstv4l2bufferpool.c:721:gst_v4l2_buffer_pool_streamon:STREAMON 32 出错(管道断裂)
0:00:00.259393750 784 0xffffb4000b70 ERROR bufferpool gstbufferpool.c:572:gst_buffer_pool_set_active:start failed
0:00:00.259435250 784 0xffffb4000b70 WARN v4l2src gstv4l2src.c:955:gst_v4l2src_decide_allocation:错误:分配所需内存失败。
0:00:00.259461750 784 0xffffb4000b70 WARN v4l2src gstv4l2src.c:955:gst_v4l2src_decide_allocation:错误:缓冲池激活失败
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Failed to allocate required memory.
其他调试信息:
/usr/src/debug/gstreamer1.0-plugins-good/1.24.0.imx/sys/v4l2/gstv4l2src.c(955): gst_v4l2src_decide_allocation ():/GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
缓冲池激活失败
0:00:00.259690375 784 0xffffb4000b70 WARN basesrc gstbasesrc.c:3395:gst_base_src_prepare_allocation:子类未能决定分配
执行在 0:00:00.015445250 后结束
将管道设置为 NULL ...
0:00:00.259771000 784 0xffffb4000b70 WARN basesrc gstbasesrc.c:3175:gst_base_src_loop:错误:内部数据流错误。
0:00:00.259796500 784 0xffffb4000b70 WARN basesrc gstbasesrc.c:3175:gst_base_src_loop:error: streaming stopped, reason not-negotiated (-4)
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
附加调试信息:
/usr/src/debug/gstreamer1.0/1.24.0.imx/libs/gst/base/gstbasesrc.c(3175):gst_base_src_loop ():/GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Freeing pipeline ...
GStreamer 命令完成。
Re: nxp 6.6.36 kernel for camera ar0144 on iMX8MM board to capture image or videos这是设备树的解决方案Re: nxp 6.6.36 kernel for camera ar0144 on iMX8MM board to capture image or videos好的,我会联系您并向您报告最新情况。
谢谢、
我检查了日志文件,你们的 csi 驱动程序似乎与 nxp 源代码不一样,我们使用 imx6s-csi 作为 csi 驱动程序,而 mipi csi 驱动程序也不一样,因为你们使用了不同的源代码,我建议你们可以联系第三方公司来检查这一点。
cat arch/arm64/启动/dts/freescale/imx8mm-phyboard-polis-vm016-fpdlink-port0.dtso
// SPDX 许可证标识符: (GPL-2.0+)OR MIT)
* Copyright (C) 2025 PHYTEC Messtechnik GmbH
* Author:Stefan Riedmüller
/dts-v1/;
/plugin/;
#include"imx8mm-phyboard-polis-fpdlink-port0.dtsi"
#include
&i2c_csi1_port0 {
camera@10 {
#address-cells =<0x1>;
#size-cells =<0x0> ;
compatible ="onsemi,ar0144";
reg =<0x10>;
/* ADD THIS LINE FOR VERIFICATION */
debug-overlay-version ="1.0" ;
/*-----------------------------------------------*/ clocks = < & ser_csi1_port0 >;
时钟名称 = " ext "; isp-bus-info = " csi0 ";
分配的时钟 =<& ser_csi1_port0>;
分配的时钟频率 =<26666666> ;
reset-gpios = < & ser_csi1_port0 3 GPIO_ACTIVE_LOW >;
onsemi,reset-delay-ms =<100> ;
port@0 {
reg =<0> ;
vm016_csi1_port0_ep:端点 {
远程端点 = < & ser_csi1_port0_in >;
总线类型 =<4> ;/* MIPI CSI-2 D-PHY */
链接频率 = /bits/ 64<222750000> ;数据通道
=<1 2> ;时钟通道
<0>=;
时 钟非连续<1> =;
onsemi,t-hs-prep =<1> ;
onsemi,t-clk-post<9>
eeprom@56 {
compatible ="atmel,24c02";
reg =<0x56>;
pagesize =<16>;
&ser_csi1_port0_in {
remote-endpoint =<& vm016_csi1_port0_ep>;
data-lanes =<1 2>;
Re: nxp 6.6.36 kernel for camera ar0144 on iMX8MM board to capture image or videosU-启动 SPL 2021.04+gd8801c557a3+p0(2022年3月21日-10:56:25 +0000)p
hytec_eeprom_data_init:成功初始化 S
oM:PCL-069-1032311I.A3 PCB 修订版:3a DDRINFO:启动 DDRINFO:DDRINFO:DDRINFO:dd
rinfo 配置完成正常启动正在尝试从 MMC2 启动通知:BLDRIX 31:v2.4(发布):lf-5.10.72-2.2.0-0-g5782363f9 通知:BL31:构建时间:2021 年 11 月 18 日 12:17:17 U-Boot 2021.04+g
d8801c557a3
+p0
(2022 年 3 月 21 日-10:56:25 +0000)
CPU:i.MX8MMQ rev1.0 1600 MHz (在 1200 MHz 下运行)
CPU:31 摄氏度时的工业温度等级 (-40C 至 105C)
RESET 原因:POR
型号:PHYTEC phyCORE-i.MX8MM
看门狗已启用
动态随机存取存储器(DRAM):2 GiB
MMC:FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
正在从 MMC 加载环境... OK
In:串行
Out:串行
Err:串行
闪存目标是 MMC:2
Net:eth0:以太网@30be0000
Fastboot:正常
正常启动
按任意键停止自动启动:0
切换到分区 #0,OK
mmc2 (第 0 部分) 是当前设备
38154752 字节读取 835 毫秒 (43.6 MiB/s)
正在从 mmc 启动...
clk qspi_root_clk 已禁用
SF:检测到 n25q256ax1 页面大小为 256 字节,擦除大小为 64 KiB,总计 32 MiB
无法加载 "bootenv.txt"
在 22 毫秒 (2.5 MiB/s) 内读取 57016 字节
找到 0 个扩展板。
在 5 毫秒内读取 3616 字节 (706.1 KiB/s)
将图像从 0x40480000 移动到 0x40600000,end=42b10000
## 扁平化设备树 blob 在 4800000 处使用 fdt blob 启动将设备树加载到 00000000bdf01000,结束 000000bdf12fff...
启动内核...
[0.000000] 在物理 CPU 上启动 Linux 0x0000000000 [0x410fd034] [0.000000] Linux 版本 6.6.36-lts-next-g181072984ef3
(oe-user @OE-host) (aarch64-参考发行版、系统开发套件。-linux-gcc (GCC) 13.3.0,GNU ld (GNU Binutils) 2.42.0.20240716) #1 SMP PREEMPT Wed Sep 4 08:22:45 UTC 2024
[ 0.000000] KASLR 因缺少种子而被禁用
[ 0.000000] 机器型号:PHYTEC phyBOARD-Polis-i.MX8MM RDK
[ 0.000000] efi:未找到 UEFI。
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095e00000, size 640 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem:0x0000000095e00000..0x00000000bddfffff (655360 KiB) map reusable linux,cma
[ 0.000000] NUMA: 未找到 NUMA 配置
[ 0.000000] NUMA: 在 [mem 0x0000000040000000-0x00000000bfffffffff] 处伪造一个节点
[ 0.000000] NUMA:NODE_DATA [mem 0xbfbb86c0-0xbfbbafff]
[ 0.000000] 区域范围:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] DMA32 空
[ 0.000000] 正常空
[ 0.000000] 每个节点的可移动区域开始
[ 0.000000] 早期内存节点范围
[ 0.000000] 节点 0: [mem 0x0000000040000000-0x00000000bfffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci:固件中检测到 PSCIv1.1。
[ 0.000000] psci:使用标准 PSCI v0.2 功能 ID
[ 0.000000] psci:不支持 MIGRATE_INFO_TYPE。
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: 嵌入式 22 页/cpu s50536 r8192 d31384 u90112
[ 0.000000] 检测到 CPU0 上的指令缓存
[ 0.000000] CPU 特性:已检测:GIC 系统寄存器 CPU 接口
[ 0.000000] CPU 功能:已检测:Arm 勘误表 845719
[ 0.000000] 备选方案:正在应用启动替代方案
[ 0.000000] 内核命令行:console=ttymxc2,115200 root=/dev/mmcblk2p2 fsck.repair=yes rootwait rw
[ 0.000000] 登入缓存哈希表条目:262144(顺序:9,2097152 字节,线性)
[ 0.000000] 索引节点缓存哈希表条目:131072(顺序:8,1048576 字节,线性)[ 0.000000] 节点 0 的回退顺序:0
[ 0.000000] 内置 1 个区域列表,移动分组开启。
总页数:516096
[ 0.000000] Policy zone:DMA
[ 0.000000] Mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x000000008fe00000-0x0000000093e00000] (64MB)
[ 0.000000] Memory: 1296904K/2097152K available (21504K kernel code, 2124K rwdata, 8616K rodata, 4864K init, 643K bss, 144888K reserved, 655360K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] RCU:可抢占式分层 RCU 实现。
[ 0.000000] RCU:已启用 RCU 事件跟踪。
[ 0.000000] RCU:RCU 限制 NR_CPUS=256 至 nr_cpu_ids=4 的 CPU。
[ 0.000000] 启用了任务 RCU 的蹦床变体。
[ 0.000000] 启用任务 RCU 的跟踪变量。
[ 0.000000] RCU:RCU 计算出的调度程序启动延迟值为 25 jiffies。
[ 0.000000] rcu:Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC:使用分割 EOI/Deactivate 模式
[ 0.000000] GICv3:实现 128 个 SPI
[ 0.000000] GICv3:实现 0 个扩展 SPI
[ 0.000000] 根 IRQ 处理程序:gic_handle_irq
[ 0.000000] GICv3:GICv3 功能:16 个 PPI
[ 0.000000] GICv3: CPU0: 发现再分配器 0 区域 0:0x0000000038880000
[ 0.000000] ITS:No ITS available, not enabling LPIs
[ 0.0000000000] rcu: srcu_init:根据争用情况设置 srcu_struct 大小。
[ 0.000000] arch_timer: cp15 定时器以 8.00MHz 运行(物理)。
[0.000000] 时钟来源:arch_sys_counter:掩码:0xfffffffffff max_cycles:0x1d854df40,max_idle_ns:440795202120 ns
[0.000000] sched_clock:8MHz 时为 56 位,分辨率 125ns,每 2199023255500ns 封装一次 [0.000470] 主机版:彩色虚拟设备 80x25 [0.000531] 校准延迟循环(跳过),使用计时器频率计算的值... 16.00 bogoMips(lpj=32000)[0.000542] pid_max:默认值:32768 最小值:301
[0.000604] LSM:初始化 lsm=能力,完整性
[0.000678] 挂载缓存哈希表条目:4096(订单:3,32768)
字节,线性)
[0.000690] MountPoint-Cache 哈希表条目:4096(顺序:3,32768 字节,线性)
[0.002146] RCU 任务:将 shift 设置为 2,lim 设置为 1 rcu_task_cb_adjust=1。
[0.002216] RCU 任务跟踪:将 shift 设置为 2 并将 lim 设置为 1 rcu_task_cb_adjust=1。
[0.002387] rcu:分层 SRCU 实现。
[ 0.002391] RCU:最大相位无延迟实例数为 1000。
[ 0.004403] EFI 服务将不可用。
[0.004679] smp:带来} p 个辅助 CPU...
[0.005148] 在 CPU1 上检测到 VIPT 指令缓存 [0.005213] GICv3:CPU1:找到再分配器 1 区域 0:0 x00000000388a0000
[0.005254] CPU1:启动辅助处理器 0x0000000001 [0x410fd034] [0.005766] 在 CPU2 上检测到 VIPT 指令缓存
[0.005810] GICv3:CPU2 上检测到 VIPT 指令缓存 PU2:找到了再分配器 2 区域 0:0 x00000000388c0000 [0.005833] CPU2:已启动辅助处理器 0x0000000002 [0x410fd034]
[0.006303] 在 CPU3 上检测到 VIPT 指令缓存 [0.006349] GICv3:CPU3:找到再分配器 3 区域 0:0 x00000000388e0000
[0.006372] CPU3:已启动
辅助处理器 0x0000000003 [0x410fd034] [0.006438] smp:启动了 1 个节点,4 个 CPU
[0.006444] SMP:共激活了 4 个处理器。
[0.006448] CPU 功能:已检测:32 位 EL0 支持
[0.006451] CPU 功能:已检测:32 位 EL1 支持 [0.006455] CPU 功能:已检测:CRC32 指令 [0.006519] CPU:所有 CPU 从 EL2 启动
[0.006541] 备选方案:应用全系统替代
方案
[0.008384] devtmpfs:初始化
[0.016448] 时钟来源:jiffies:掩码:0xfffffff max_cycles:0xfffffff,max_idle_ns:7645041785100000 ns
[0.016474] futex 哈希表条目:1024(顺序:4,65536 字节,线性)[0.035040] pinctrl 内核:初始化 pinctrl
子系统
[0.037321] DMI 不存在或无效。
[ 0.037920] NET:已注册的 PF_NETLINK/PF_ROUTE 协议系列
[ 0.039736] DMA:为原子分配预分配的 256 KiB GFP_KERNEL 池
[ 0.040718] DMA:预分配的 256 KiB GFP_KERNEL|GFP_DMA 池用于原子分配
[ 0.041701] DMA:预分配的 256 KiB GFP_KERNEL|GFP_DMA32 池用于原子分配
[ 0.041802] audit:初始化 netlink 子系统(禁用)
[ 0.042023] audit:type=2000 audit(0.040:1):state=initialized audit_enabled=0 res=1
[ 0.042594] thermal_sys:Registered thermal governor 'step_wise'
[ 0.042598] thermal_sys:Registered thermal governor 'power_allocator'
[ 0.042640] cpuidle: using governor menu
[ 0.042884] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.042969] ASID 分配器初始化为 65536 个条目
[ 0.043958] 串行:AMBA PL011 UART 驱动程序
[ 0.044030] imx mu 驱动程序已注册。
[ 0.044050] imx rpmsg 驱动程序已注册。
[ 0.050386] platform soc@0: Fixed dependency cycle(s) with /soc@0/bus@30000000/efuse@30350000/unique-id@4
[ 0.053133] imx8mm-pinctrl 30330000.pinctrl:初始化了 IMX pinctrl 驱动程序
[ 0.053556] platform 30350000.efuse:修复了 /soc@0/bus@30000000/clock-controller@30380000 的依赖周期
[ 0.054628] 平台 30350000.efuse:修复了与 /soc@0/bus@30000000/clock-controller@30380000 的依赖周期
[ 0.062454] 平台 32e20000.csi-upstream:修正了与 /soc@0/bus@32c00000/mipi-csi-upstream@32e30000 的依赖循环
[ 0.062759] 平台 32e20000.csi-upstream:修正了与 /soc@0/bus@32c00000/mipi-csi-upstream@32e30000 的依赖循环
[ 0.062878] 平台 32e30000.mipi-csi-upstream:修正了与 /soc@0/bus@32c00000/csi-upstream@32e20000 的依赖循环
[ 0.062966] 平台 32e30000.mipi-csi-upstream:修正了 /soc@0/bus@30800000/i2c@30a50000/deserializer@30 的依赖循环
[ 0.067441] 模块:23280 页在非 PLT 使用范围内
[ 0.067449] 模块:514800 pages in range for PLT usage
[ 0.068142] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.068149] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB 页面
[ 0.068153] HugeTLB: 已注册 32.0 MiB 页面大小,预分配 0 个页面
[ 0.068156] HugeTLB: 0 KiB vmemmap 可释放 32.0 MiB 页面
[ 0.068161] HugeTLB:已注册 2.00 MiB 页面大小,预分配 0 个页面
[ 0.068166] HugeTLB:0 KiB vmemmap 可为 2.00 MiB 页面释放
[ 0.0.068170] HugeTLB: 已注册 64.0 KiB 页面大小,预分配 0 个页面
[ 0.068175] HugeTLB: 0 KiB vmemmap 可为 64.0 KiB 页面释放
[ 0.070112] ACPI:禁用解释器。
[ 0.071049] iommu: 默认功能域类型: 已翻译
[ 0.071058] iommu: DMA 功能域 TLB 失效政策: 严格模式
[ 0.071364] SCSI 子系统已初始化
[ 0.071668] usbcore: 注册了新的接口驱动程序 usbfs
[ 0.071696] usbcore: 注册了新的接口驱动程序 hub
[ 0.071732] usbcore: 注册了新的设备驱动程序 usb
[ 0.072703] mc: Linux 媒体接口: v0.10
[ 0.072743] videodev: Linux 视频捕获接口: v2.00
[ 0.072804] pps_core: LinuxPPS API 版本 1 已注册
[ 0.072808] pps_core: 软件版本 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
[ 0.072821] PTP 时钟支持注册
[ 0.072973] EDAC MC: Ver:3.0.0
[0.073391] scmi_core:SCMI 协议总线已注册
[0.073806] FPGA 管理器框架 [0.073882] 高级 Linux 声音架构驱动程序已初始化。
[ 0.074597] 蓝牙:核心版本 2.22
[ 0.074625] NET:注册的 PF_BLUETOOTH 协议系列
[ 0.074629] 蓝牙:HCI 设备和连接管理器已初始化
[ 0.074636] 蓝牙:HCI 套接字层已初始化
[ 0.074641] 蓝牙:L2CAP 套接字层已初始化
[ 0.074653] 蓝牙:SCO 套接字层已初始化
[ 0.074967] vgaarb: loaded
[ 0.075439] clocksource:切换到 clocksource arch_sys_counter
[ 0.075662] VFS:磁盘配额 dquot_6.6.0
[0.075687] VFS:dquot-Cache 哈希表条目:512(顺序 0,4096 字节)
[0.075862] pnp:PnP ACPI:禁用
[0.082648] NET:注册的 PF_INET 协议系列
[0.082804] IP 标识符哈希表条目:32768(顺序:6,262144 字节,线性)
[0.084353] tcp_list3 en_portaddr_hash 哈希表条目:1024(顺序:2,16384 字节,线性)
[0.084380] table-perturb 哈希表条目:65536(顺序:6,262144 字节,线性)
[0.084393] TCP 已建立的哈希表条目:16384(顺序:5,131072 字节,线性)
[0.084539] TCP 绑定哈希表条目:16384(顺序:7,524288 字节,线性)
[0.084995] TCP:已配置哈希表(已建立 16384 绑定 16384)
[0.085090] UDP 哈希表条目:1024(顺序:3,32768 字节,线性)
[0.085139] UDP-Lite 哈希表条目:1024(顺序:3,32768 字节,线性)
[0.085289] NET:注册的 PF_UNIX/PF_LOCAL 协议系列
[0.085707] RPC:已注册命名的 UNIX 套接字传输模块。
[ 0.085712] rpc:注册了 udp 传输模块。
[ 0.085715] rpc:注册了 tcp 传输模块。
[ 0.085717] rpc:注册了 tcp-with-tls 传输模块。
[ 0.085720] rpc:Registered tcp NFSv4.1 backchannel transport module.
[0.086755] PCI:CLS 0 字节,默认 64 [0.087116] kvm [1]:IPA 大小限制:40 位
[0.089341] kvm [1]:GICv3:没有 GICV 资源条目 [0.089348] kvm [1]:禁用 GICv2 仿真
[0.089363] kvm [1]:启用 GIC 系统寄存器 CPU 接口 [0.089348] kvm [1]:启用 GIC 系统寄存器 CPU 接口
[0.089348] kvm [1]:启用 GIC 系统寄存器 CPU 接口 [0.089348] kvm 9389] kvm [1]:vgic 中断 IRQ9
[0.089413] kvm [1]:Hyp 模式成功初始化 [0.090583] 初始化系统可信密钥环
[0.090763] 工作集:timestamp_bits=42 max_order=19 bucket_order=0
[0.091050] squashfs:版本 4.0(2009/01/31)Lougher
[0.091253] NFS:注册 id_resolver 密钥类型 [0.091273] 密钥类型 id_resolver 已注册
[0.091277] 密钥类型 id_legacy 已注册
[0.091301] nfs4filelayout_init:NFSv4 文件布局驱动程序正在注册...
[0.091306] nfs4flexfileLayout_init:NFSv4 Flexfile 布局驱动程序正在注册...
[0.091326] jffs2:版本 2.2。(与非) © 2001-2006 Red Hat, Inc.
[0.091544] 9p:安装 v9fs 9p2000 文件系统支持 [0.125118] 密钥类型非对称注册 [0.125124] 非对称密钥解析器 “x509” 已注册
[0.125165] 区块层 SCSI 通用 (bsg) 驱动程序版本 0.4(主要 243)[0.125171] io 调度器 mq-deadline 已注册
[0.125165] 175] io 调度器 kyber 已注册 [0.125203] io 调度器 bfq 已注册
[0.131226] EINJ:ACPI 已禁用。
[ 0.142324] imx-sdma 302c0000.dma-controller:直接加载 imx/sdma/sdma-imx7d.bin 固件失败,错误 -2
[ 0.142342] imx-sdma 302c0000.dma-controller:回退到 sysfs 后备: imx/sdma/sdma-imx7d.bin
[ 0.150358] mxs-dma 33000000.dma-controller:已初始化
[0.151638] SoC:i.mx8mm 修订版 1.0
[0.152079] 总线频率驱动模块已加载 [0.164497] 串行:8250/16550 驱动程序,4 个端口,启用 IRQ 共享
[0.167407] 30860000.serial:
MMIO 0x30860000 处的 ttymxc0(irq = 18,base_baud = 5000000)是 IMX
[ 0.168171] 30880000.serial:位于 MMIO 0x30880000 的 ttymxc2(irq = 19,base_baud = 1500000)是 IMX
[ 0.168200] printk:已启用控制台 [ttymxc2]
[ 1.352172] 30890000.serial:位于 MMIO 0x30890000 的 ttymxc1(irq = 20,base_baud = 5000000)是一个 IMX
[1.361283] 串行序列号 0:tty 端口 ttymxc1 已注册
[1.368286] imx-drm 显示子系统:没有可用端口
[1.385950] 循环:模块已加载
[1.390781] megasas:07.725.01.00-rc1
[1.399300] spi-或非 spi3.0:n25q256ax1 (32768 KB)
[1.404534] 在 MTD 设备上找到 4 个固定分区分区 30bb0000.spi
[ 1.411423] 在"30bb0000.spi 上创建 4 个 MTD 分区" :
[1.416753] 0x000000000000-0x0000003c0000 : "u-启动"
[ 1.422851] 0x0000003c0000-0x0000003e0000 : "env"
[ 1.428576] 0x0000003e0000-0x000000400000 : "env_redund"
[ 1.434871] 0x000000400000-0x000002000000 : "none"
[ 1.443798] tun: 通用 TUN/TAP 设备驱动程序, 1.6
[ 1.449701] thunder_xcv, ver 1.0
[ 1.452971] thunder_bgx, ver 1.0
[ 1.456236] nicpf, ver 1.0
[ 1.460950] hns3: 适用于 Hip08 系列的海思以太网网络驱动程序 - 版本
[ 1.468186] hns3: 版权所有 (c) 2017 华为公司。
[ 1.473539] hclge 正在初始化
[ 1.476895] e1000:英特尔(R) PRO/1000 网络驱动程序
[ 1.481781] e1000:版权所有 (c) 1999-2006 英特尔公司。
[ 1.487560] e1000e:英特尔(R) PRO/1000 网络驱动程序
[ 1.492532] e1000e:版权所有(c) 1999 - 2015 英特尔公司。
[ 1.498488] IGB:英特尔(R)千兆以太网网络驱动程序
[ 1.503934] igb:版权所有 (c) 2007-2014 英特尔公司。
[ 1.509542] igbvf:英特尔(R) 千兆位虚拟功能网络驱动程序
[ 1.515818] igbvf:版权所有 (c) 2009 - 2012 英特尔公司。
[1.521900] sky2:驱动程序版本 1.30
[1.526092] usbcore:注册的新设备驱动程序 r8152-cfgselector [1.532402] usbcore:注册了新的接口驱动程序 r8152
[1.538347] VFIO-用户级别元驱动程序版本:0.3 [1.546053] usbcore:注册的新接口驱动程序 uas
[1.551412] usbcore:已注册新接口驱动程序 usbstorage [1.557501] usbcore:注册了新的接口驱动程序 usbserial_generic
[1.564058] usbserial:已注册通用接口驱动程序
[1.570091] usbcore:注册了新的接口驱动程序
ftdi_sio
[1.575867] usbserial:为 FTDI USB 串行设备注册了 USB 串行支持 [1.583209] usbcore:注册了新的接口驱动程序 usb_serial_simple
[1.589763] usbserial:USB 串行支持已注册为 Carelink
[1.595881] usbserial:USB 串行支持注册为 funsoft [1.608296] usbserial:谷歌注册了 USB 串行支持
[1.614251] usbserial:USB 串行支持已注册到 hp4x [1.620026] usbserial:USB 串行支持已注册到 hp4x
注册了 kaufmann
[1.626148] usbserial:注册了 libtransistor 的 USB 串行支持 [1.632703] usbserial:USB 串行支持注册为 moto_modem
[1.638996] usbserial:USB 串行支持已注册为摩托罗拉_tetra [1.645638] usbserial:已注册 USB 串行支持 novate_tetra
[1.645638] usbserial:USB 串行支持已注册为诺基亚 [1.651500] usbserial:USB 串行支持已注册为 novateTra
[1.645638] l_gps [1.657887] usbserial:为 siemens_mpi [1.664267] 注册了 USB 串行支持 usbserial:为 suunto
[1.670217] 注册了 USBSERIAL 支持 usbserial:USB 串行支持
vivopay
[1.676250] 已注册串行支持 usbserial:USB 串行支持已注册为 zio [1.681941] usbcore:注册了新的接口驱动程序 usb_ehset_test
[1.691140] 输入:30370000.snvs: snvs-powerkey
作为 /设备/platform/soc @0 /30000000.bus/30370000.snvs/30370000.snvs: snvs-powerkey/input/input/input0
[ 1.705823] snvs_rtc 30370000.snvs:snvs-rtc-lp:注册为 rtc1
[ 1.712152] i2c_dev: i2c /dev entries 驱动程序
[ 1.718141] imx7-csi 32e20000.csi-upstream:将 csi 捕获注册为 /dev/video0
[1.730126] 蓝牙:HCI UART 驱动程序版本 2.3 [1.734606] 蓝牙:HCI UART 协议 H4 已注册
[1.739761] 蓝牙:HCI UART 协议 BCSP 已注册 [1.745111] 蓝牙:HCI UART 协议 ATH3K 已注册
[1.7556111] 蓝牙:HCI UART 协议已注册 [1.7556111] 蓝牙:HCI UART 协议已注册
[1.7556257] 80] 蓝牙:HCI UART 协议三线 (H5) 已注册
[1.762060] 蓝牙:HCI UART 协议 Broadcom 已注册 [1.767754] 蓝牙:HCI UART 协议 QCA 已注册
[1.774564] sdhci:安全
数字主机控制器接口驱动程序
[1.780770] sdhci:版权所有 (c) Pierre Ossman [1.785650] Synopsys Designware 多媒体卡接口驱动程序
[1.792266] sdhci-pltfm:SDHCI 平台和 OF 驱动程序助手
[1.800696] ledtrig-cpu:注册以表示 CPU [1.808203] SMCCC:SOC_ID:ARCH_SOC_COC_ID 未实现,正在跳过...
[1.814776] usbcore:注册了新的接口驱动程序 usbhid [1.820362] usbhid:USB HID 核心驱动程序
[1.829277] hw perfevents:启用 armv8_cortex_a53 PMU 驱动程序,7 个计数器可用
[1.830960] mmc2:30b60000.mmc 上的 SDHCI 控制器 [30b60000.mmc]]
使用 ADMA
[ 1.840167] cs_system_cfg: CoreSight 配置管理器已初始化
[ 1.852235] platform soc@0: 固定了与 /soc@0/bus@30000000/efuse@30350000 的依赖循环
[ 1.863774] hantrodec 0 : 已插入模块。Major = 509
[ 1.869494] hantrodec 1 : 已插入模块。Major = 509
[ 1.875561] hx280enc: 已插入模块。主要 <508>
[1.884974] NET:注册的 PF_LLC 协议系列
[1.889882] u32 分类器
[1.892646] 输入设备检查
[1.896316] 配置的操作
[1.900980] NET:注册的 PF_INET6 协议系列
[1.908303] 使用 IPv6 的分段路由
[1.912020] 使用 IPv6 进行原位 OAM (IOAM)
[1.916000] NET:注册的 PF_PACKET 协议系列
[1.921080] 网桥:默认情况下,通过 arp/ip/ip6tables 进行过滤不再可用。如果需要,请更新您的脚本以加载 br_netfilter。
[1.925708] mmc2:地址为 0001 [1.935047] 的新款 HS400 增强型频闪 MMC 卡蓝牙:RFCOMM TTY 层已初始化
[1.941342] mmcblk2:mmc 2:0001 DG4008 7.28 GiB
[1.945299] 蓝牙:RFCOMM 套接字层已初始化 [1.952211] mmcblk2:p1 p2 [1.954910] 蓝牙:RFCOMM 版本 1.11
[1.958885] mmcblk2boot0:mmc 2:0001 DG4008 4.00 MiB
[1.961446] 蓝牙:BNEP(以太网仿真)版本 1.3 [1.967672] mmcblk2boot1:mmc 2:0001 DG4008 4.00 MiB
[1.971636] 蓝牙:BNEP 过滤器:协议多播
978035] mmcblk2rpmb:mmc 2:0001 DG4008 4.00 MiB,chardev (234:0)
[1.981756] 蓝牙:BNEP 套接字层已初始化 [1.992994] 蓝牙:HIDP(人机接口仿真)版本 1.2 [1.998927] 蓝牙:HIDP 套接字层已初始化
[2.004962] 8021q:802.1Q VLAN 支持 v1.8 [2.009195] lib80211:IEEE802.11 驱动程序的常用例程
[2.014915] 9pnet:安装 9P2000 支持 [2.019342] 密钥类型 dns_resolver 已注册
[2.024383] NET:注册的 PF_VSOCK 协议系列
[2.051549] 注册的任务统计版本 1
[2.055888] 加载已编译的 X.509 证书
[2.084038] gpio gpiochip0:不推荐使用 GPIO 基础的静态分配,使用动态分配。
[ 2.094599] gpio gpiochip1:GPIO 底座的静态分配已过时,请使用动态分配。
[ 2.105135] gpio gpiochip2:GPIO 基础的静态分配已被淘汰,请使用动态分配。
[ 2.115714] gpio gpiochip3:GPIO 基础的静态分配已过时,请使用动态分配。
[ 2.126362] gpio gpiochip4:GPIO 基础的静态分配已过时,请使用动态分配。
[ 2.139269] usb_phy_generic usbphynop1: dummy supplies not allowed for exclusive requests
[ 2.147773] usb_phy_generic usbphynop2: dummy supplies not allowed for exclusive requests
[ 2.156885] i2c i2c-0: using pinctrl states for GPIO recovery
[ 2.163489] i2c i2c-0: IMX I2C adapter registered
[ 2.163886] pf8x00 0-0008:找到 PF8121A PMIC。
[ 2.169548] i2c i2c-3:使用 pinctrl 状态进行 GPIO 恢复
[ 2.178618] 平台 32e30000.mipi-csi-upstream:修正了 /soc@0/bus@30800000/i2c@30a50000/deserializer@30 的依赖周期
[ 2.180672] VDD_GPU_DRAM (BUCK2):将 900000uV 引入 1000000-1000000uV
[ 2.190282] i2c 3-0030:修正了 /soc@0/bus@30800000/i2c@30a50000/deserializer@30/links/link@0/serializer 的依赖循环
[ 2.208618] i2c 3-0030:修正了与 /soc@0/bus@32c00000/mipi-csi-upstream@32e30000 的依赖循环
[ 2.218165] i2c i2c-3: IMX I2C 适配器已注册
[ 2.225222] imx6q-pcie 33800000.pcie:host bridge /soc@0/pcie@33800000 ranges:
[ 2.231589] pps pps0: new PPS source ptp0
[ 2.232577] imx6q-pcie 33800000.pcie:IO 0x001ff80000..0x001ff8ffff -> 0x0000000000
[ 2.244757] imx6q-pcie 33800000.pcie:MEM 0x0018000000... 0x001feffff-> 0x0018000000 [2.262344] fec 30be0000.ethernet eth0:注册的 PHC 设备 0 [2.384308] ci_hdrc ci_
hdrc.1:
EHCI 主机控制器
[ 2.389237] ci_hdrc ci_hdrc.1:新的 USB 总线已注册,分配的总线编号为 1
[2.411446] ci_hdrc ci_hdrc ci_hdrc.1:USB 2.0 启动,EHCI 1.00
[ 2.418455] hub 1-0:1.0:发现 USB 集线器
[ 2.422241] hub 1-0:1.0: 检测到 1 个端口
[ 2.428135] imx-cpufreq-dt imx-cpufreq-dt: CPU 速度等级 2 mkt 段 2 supported-hw 0x4 0x4
[ 2.442738] sdhci-esdhc-imx 30b40000.mmc:已分配 mmc-pwrseq
[ 2.442742] sdhci-esdhc-imx 30b50000.mmc:Got CD GPIO
[ 2.442795] galcore: clk_get vg clock failed, disable vg!
[ 2.459770] Galcore version 6.4.11.p2.745085
[ 2.468034] imx6q-pcie 33800000.pcie:iATU: unroll T, 4 ob, 4 ib, align 64K, limit 4G
[ 2.476542] mmc1: 30b50000.mmc 上的 SDHCI 控制器 [ 30b50000.mmc]使用 ADMA
[ 2.512596] [drm] Initialized vivante 1.0.0 20170808 for 38000000.gpu on minor 0
[ 2.521705] cfg80211: Loading compiled-in X.509 certificates for regulatory database.证书
[ 2.532266] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 2.538531] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 2.545822] clk:禁用未使用的时钟
[ 2.549823] platform regulatory.0:regulatory.db 的直接固件加载失败,出现错误 -2
[2.553744] ALSA 设备列表:
[2.558453] 平台监管机构.0:回退到 sysfs 后备: regulatory.db
[ 2.561446] 没有找到声卡
[ 2.587795] mmc0: 30b40000.mmc 上的 SDHCI 控制器 [30b40000.mmc]使用 ADMA
[ 2.914968] mmc0: 地址为 0001 的新 DDR MMC 卡
[ 2.921278] mmcblk0: mmc0:0001 AS064G 57.6 GiB
[ 2.928347] mmcblk0: p1
[ 2.931919] mmcblk0boot0: mmc0:0001 AS064G 31.5 MiB
[ 2.938465] mmcblk0boot1: mmc0:0001 AS064G 31.5 MiB
[ 2.945065] mmcblk0rpmb: mmc0:0001 AS064G 4.00 MiB, chardev (234:1)
[ 3.478557] imx6q-pcie 33800000.pcie:Phy link never came up
[ 4.488194] imx6q-pcie 33800000.pcie:Phy link never came up
[ 4.494436] imx6q-pcie 33800000.pcie:PCI 主机桥接到总线 0000:00
[4.500803] pci_bus 0000:00:根总线资源 [总线 00-ff] [4.506308] pci_bus 0000:00:根总线资源 [io 0x0000-0xfff]
[4.512499] pci_bus 0000:00:根总线资源 [mem 0x18000000-0x1ffff] [4.519414] pci 0000:00 :00:00.0:
[16c3:abcd] type 01 class 0x060400
[ 4.525437] pci 0000:00:00.0:reg 0x10: [mem 0x00000000-0x000fffff]
[ 4.531727] pci 0000:00:00.0:reg 0x38: [mem 0x00000000-0x0000ffff pref]
[ 4.538477] pci 0000:00:00.0:支持 D1
[ 4.542505] pci 0000:00:00.0:D0 D1 D3hot D3cold 支持 PME#
[ 4.550738] pci 0000:00:00.0:BAR 0: 已分配 [mem 0x18000000-0x180fffff]
[ 4.557558] pci 0000:00:00.0:BAR 6: 分配 [mem 0x18100000-0x1810ffff pref]
[ 4.564792] pci 0000:00:00.0:PCI 桥接到 [总线 01-ff]
[4.570485] pcieport 0000:00:00.0:PME:使用 IRQ 219 发送信号
[ 4.663475] EXT4-fs (mmcblk2p2): 恢复完成
[ 4.669010] EXT4-fs (mmcblk2p2): 已挂载文件系统 f64eecf7-ac82-4a6b-b54b-82bd93bf1c9b r/w,数据模式为有序。配额模式:无。
[4.675447] 蓝牙:hci0:命令 0xfc18 tx 超时
[4.681172] VFS:在设备 179:2 上挂载根目录(ext4 文件系统)。
[ 4.686260] 蓝牙:hci0:BCM:无法写入更新波特率 (-110)
[ 4.692685] devtmpfs:已挂载
[ 4.698966] 蓝牙:hci0:无法设置波特率
[ 4.703789] 释放未使用的内核内存:4864K
[ 4.711452] 将 /sbin/init 作为初始进程运行
[ 4.843082] systemd[1]:版本时间之前的系统时间,将时钟提前。
[ 4.882792] systemd[1]: systemd 255.4^ 以系统模式运行(+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPT)
[ 4.914701] systemd[1]:检测到架构 arm64。
欢迎来到恩智浦 i.MX 版本 发行版 6.6-scarthgap (scarthgap)!
[ 4.940511] systemd[1]:主机名设置为.
[ 5.347309] systemd[1]:为默认目标图形界面排队启动作业。
[ 5.381152] systemd[1]:Created slice Slice /system/getty.
[ 确定 ] 已创建片段/system/getty。
[ 5.405844] systemd[1]:创建了片段 Slice /system/modprobe.
[ 确定 ] 已创建片段 Slice /system/modprobe。
[ 5.429820] systemd[1]:Created slice Slice /system/serial-getty.
[ OK ] Created slice Slice /system/serial-getty.
[ 5.452964] systemd[1]:创建了片段用户和会话片段。
[ 确定 ] 创建了片段 "用户 "和 "会话片段"。
[ 5.476285] systemd[1]:Started Dispatch Password Requests to Console Directory Watch.
[ 确定 ] 开始向控制台目录监视器发送密码请求。
[ 5.499815] systemd[1]:Started Forward Password Requests to Wall Directory Watch.
[ 确定 ] 开始将密码请求转发至 Wall Directory Watch。
[ 5.524152] systemd[1]:Reached target Host and Network Name Lookups.
[ 确定 ] 已达到目标主机和网络名称查询。
[ 5.547938] systemd[1]:Reached target Path Units.
[ 确定 ] 到达目标路径单位。
[ 5.567601] systemd[1]:到达目标远程文件系统。
[ 确定 ] 已到达目标远程文件系统。
[ 5.591978] systemd[1]:Reached target Slice Units.
[ 确定 ] 到达目标切片单位。
[ 5.611970] systemd[1]:Reached target Swaps.
[确定] 达到目标交换。
[ 5.669129] systemd[1]:监听 RPCbind 服务器激活套接字。
[ 确定 ] 正在监听 RPCbind 服务器激活套接字。
[ 5.695732] systemd[1]:到达目标 RPC 端口映射器。
[ 确定 ] 到达目标 RPC 端口映射器。
[ 5.716617] systemd[1]:监听 Syslog Socket。
[ 确定 ] 正在监听 Syslog Socket。
[ 5.736341] systemd[1]:Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 5.761666] systemd[1]:监听日志审计套接字。
[ 确定 ] 正在监听日志审计套接字。
[ 5.784100] systemd[1]:监听日志套接字 (/dev/log)。
[ 确定 ] 正在监听日志套接字 (/dev/log)。
[ 5.808700] systemd[1]:监听日志套接字。
[ 确定 ] 正在监听日志套接字。
[ 5.828425] systemd[1]:监听网络服务 Netlink Socket。
[正在监听网络服务 Netlink 插口。
[ 5.856821] systemd[1]:监听 udev 控制套接字。
[ 确定 ] 正在监听 udev 控制套接字。
[ 5.880417] systemd[1]:监听 udev 内核套接字。
[正在监听 udev 内核套接字。
[ 5.904597] systemd[1]:监听用户数据库管理器套接字。
[ 确定 ] 正在监听用户数据库管理器套接字。
[ 5.951764] systemd[1]:Mounting Huge Pages File System...
[ 5.976447] systemd[1]:挂载 POSIX 消息队列文件系统...
[ 6.007195] systemd[1]:挂载内核调试文件系统...
挂载内核调试文件系统...
[ 6.032253] systemd[1]:由于未满足条件检查(ConditionPathExists=/sys/kernel/tracing),内核跟踪文件系统被跳过。
[6.050044] systemd [1]:正在装入临时目录 /tmp...
正在装入临时目录 /tmp...
[6.077423] systemd [1]:正在开始创建静态设备节点列表...
正在开始创建静态设备节点列表...
[6.107253] systemd [1]:正在启动加载内核模块 configfs...
[6.136019] systemd [1]:正在启动加载内核模块 drm...
正在启动加载内核模块 drm...
[6.164064] systemd [1]:启动加载内核模块熔丝...
正在启动加载内核模块熔丝...
[6.189233] systemd [1]:正在启动 RPC 绑定...
正在启动 RPC 绑定...
[6.199500] fuse: init(API 版本 7.39)
[6.207816] systemd [1]:由于条件检查未满足,跳过了根设备上的文件系统检查 (conditionpathisReadWrite=!/)。
[6.228073] systemd [1]:正在启动日记服务...
正在启动日记服务...
[6.249651] systemd [1]:由于未满足触发信号检查,因此跳过了加载内核模块。
[6.283597] systemd [1]:正在启动 “从内核命令行生成网络单元”...
[6.315799] systemd [1]:开始重新安装根和内核文件系统...
正在开始重新安装根和内核文件系统...
[6.342630] systemd-journald [141]:已启用收集审计消息的功能。
[6.343415] systemd [1]:开始应用内核变量...
正在启动 “应用内核变量”...
[6.371692] systemd [1]:启动 Coldplug 所有 udev 设备...
正在启动 Coldplug 所有 udev 设备...
[6.383992] ext4-FS (mmcblk2p2):重新安装了 f64eecf7-ac82-4a6b-b54b-82bd93b-82bd93bf1c9b r/w。配额模式:无。
[ 6.424156] systemd[1]:开始虚拟控制台设置...
开始虚拟控制台设置...
[ 6.452851] systemd[1]:
[ 确定 ] 启动 6.457526] systemd[1]:启动日志服务。
;39mRPC Bind.
[ OK ] 已启动期刊服务。
[ 确定 ] 已挂载巨页文件系统。
[ 确定 ] 已挂载 POSIX 消息队列文件系统。
[ 确定 ] 已挂载内核调试文件系统。
[ 确定 ] 挂载了临时目录 /tmp。
[确定] 已完成 “创建静态设备节点列表”。
[ 确定 ] 完成加载内核模块 configfs。
[确定] 已完成加载内核模块 drm。
[确定] 加载内核模块熔丝已完成。
[ 确定 ] 完成 从内核命令行生成网络单元。
[ 确定 ] 完成重挂载根文件系统和内核文件系统。
[ 确定 ] 完成应用内核变量。
正在安装 熔丝 控制文件系统...
正在装入内核配置文件系统...
正在开始将日记刷新到永久存储...
正在优雅地启动 /dev 中创建静态设备节点...
[6.645277] systemd-journald [141]:收到客户端刷新运行时日志的请求。
[ 确定 ] 完成虚拟控制台设置。
[确定] 已安装 熔丝 控制文件系统。
[ 确定 ] 已挂载内核配置文件系统。
[ 确定 ] 完成将日志刷新到持久存储。
[确定] 在 /dev 中优雅地完成了创建静态设备节点。
[6.723480] 蓝牙:hci0:命令 0xfc18 tx 超时
[6.730191] 蓝牙:hci0:BCM:RESET 失败 (-110) 开始在 /dev... 中创建静态设备节点
[确定] 已在 /dev 中完成创建静态设备节点。
[确定] 到达目标 为本地文件系统做好准备。
Mounting /var/volatile...
[ 6.870003] audit: type=1334 audit(1709054766.024:2):prog-id=6 op=LOAD
[ 6.876808] audit: type=1334 audit(1709054766.032:3):prog-id=7 op=Load
启动基于规则的设备事件和文件管理器...
[确定] 已安装 /var/volatile。
开始加载/保存操作系统随机种子...
[ 确定 ] 到达目标本地文件系统。
开始创建易失性文件和目录...
[ 确定 ] 完成 创建易失性文件和目录。
[ 7.055329] audit: type=1334 audit(1709054766.208:4):prog-id=8 op=
Load 启动网络时间同步...
正在启动 UTMP 中录制系统启动/关闭...
[7.118446] 审计:type=1334 审计 (1709054766. 272:5):prog-id=9 op=LOAD
[ 7.145997] audit: type=1334 audit(1709054766.300:6):prog-id=10 op=LOAD
Starting User Database Manager...
[ 7.159128] audit: type=1334 audit(1709054766.300:7):prog-id=11 op=Load
[确定] 已在 UTMP 中完成录制系统启动/关闭。
[确定] 已完成 Coldplug 所有 udev 设备。
[ 确定 ] 启动用户数据库管理器。
[确定] 已启动基于规则的设备事件和文件管理器。
正在启动 Start Pslash 启动屏幕...
[确定] 已启动 Pslash 启动画面。
[ 确定 ] 已启动 启动 psplash-systemd 进度通信助手。
[ 确定 ] 开始网络时间同步。
[ 确定 ] 到达目标系统初始化。
[ 确定 ] 开始每日清理临时目录。
[ 确定 ] 已达到目标系统时间设置。
[ 确定 ] 开始每日轮换日志文件。
[ 确定 ] 到达目标计时器单位。
[ 确定 ] 正在监听 Avahi mDNS/DNS-SD 堆栈激活套接字。
[确定] 在 D-Bus 系统消息总线插槽上监听。
正在启动 API 的容器 Socket...
正在启动 sshd.socket...
正在启动 Weston 套接字...
[OK] 在容器 Socket 上监听 API。
[OK] 在 Weston 插座上收听。
[ 确定 ] 正在监听 sshd.socket。
[ 确定 ] 已到达目标插座单元。
[ 确定 ] 到达目标基本系统。
[确定] 启动作业线轴工具。
[ 确定 ] 启动定期命令调度程序。
正在启动 D-Bus 系统消息总线...
[确定] 已启动 Linux 固件加载器守护程序。
[ 确定 ] 开始配置 i.MX GPU(原 rc_gpu.S)。
[ 8.089289] imx-sdma 30bd0000.dma-controller:发现固件。
[ 8.091531] imx-sdma 302b0000.dma-controller:固件已找到。
[ 8.096491] imx-sdma 302c0000.dma-controller:固件已找到。
[ 8.103179] imx-sdma 302b0000.dma-controller:加载固件 4.6
启动 IPv6 包过滤框架...
启动 IPv4 包过滤框架...
启动电话服务...
[ 确定 ] 已启动 将 psplash 更新为 basic。
[ 确定 ] 启动了系统日志服务。
[ 8.231400] audit: type=1334 audit(1755159888.412:8):prog-id=12 op=LOAD
[ 8.239611] audit: type=1334 audit(1755159888.424:9):prog-id=13 op=LOAD
[ 8.247361] audit: type=1334 audit(1755159888.428:10):prog-id=14 op=LOAD
启动用户登录管理...
启动 OpenSSH 密钥生成...
[ OK ] 完成 IPv6 包过滤框架。
[ 确定 ] 完成 IPv4 数据包过滤框架。
[ 确定 ] 已达到目标 网络准备就绪。
开始网络配置...
[ 确定 ] 开始用户登录管理。
[ 确定 ] 开始网络配置。
启动蓝牙服务......
[ 确定 ] 完成加载/保存操作系统随机种子。
[ 确定 ] 完成 OpenSSH 密钥生成。
[ 确定 ] 到达目标 硬件已激活 USB 小工具。
[确定] 已启动 D-Bus 系统消息总线。
正在启动连接服务...
[确定] 已启动蓝牙服务。
[ 确定 ] 启动电话服务。
[ 确定 ] 启动连接服务。
[ 确定 ] 创建了片段 Slice /system/systemd-fsck.
[ 确定 ] 到达目标蓝牙支持。
启动 Avahi mDNS/DNS-SD 堆栈...
启动 /dev/mmcblk0p1 上的文件系统检查...
启动 /dev/mmcblk2p1 上的文件系统检查...
启动主机名服务...
启动 WPA 支持程序...
[ 确定 ] 停止虚拟控制台设置。
停止虚拟控制台设置...
启动虚拟控制台设置...
[ 确定 ] 启动 Avahi mDNS/DNS-SD 堆栈。
[ 确定 ] 启动 WPA 支持者。
[ 确定 ] 已到达目标网络。
Starting containerd container runtime...
[ OK ] Started Network Time Service.
[ OK ] Started Update psplash to network.
正在启动 “终止 Pslash 启动屏幕”...
正在启动许可用户会话...
[确定] 已完成 /dev/mmcblk2p1 上的文件系统检查。
[ 确定 ] 完成虚拟控制台设置。
正在安装 /run/media/boot-mmcblk2p1...
[失败] 无法启动 “终止 Pslash 启动屏幕”。
请参见 "systemctl status psplash-quit.service"。
[ 确定 ] 完成 允许用户会话。
[ 确定 ] 在 tty1 上启动 Getty。
[ 确定 ] 在 ttymxc2 上启动串行 Getty。
[ 确定 ] 已达到目标登录提示。
将 Wayland 合成器 Weston 作为系统服务启动...
[ 确定 ] 启动主机名服务。
[确定] 已挂载 /run/media/启动-mmcblk2p1。
[确定] 已完成 /dev/mmcblk0p1 上的文件系统检查。
挂载 /run/media/emmc-mmcblk0p1...
[ 确定 ] 创建了 UID 为 0 的用户片段。
启动用户运行时目录 /run/user/0...
[ 确定 ] 挂载 /run/media/emmc-mmcblk0p1.
[ 确定 ] 完成用户运行时目录 /run/user/0...
开始保存/还原声卡状态...
启动 UID 0 的用户管理器...
[ 确定 ] 完成保存/还原声卡状态。
[ 确定 ] 到达目标声卡。
[ 确定 ] 启动 containerd 容器运行时。
[ 确定 ] 到达目标多用户系统。
[ 确定 ] 启动了 UID 0 的用户管理器。
[ 确定 ] 启动了用户 root 的会话 c1。
[FAILED] 将 Wayland 合成器 Weston 作为系统服务启动失败。
请参阅 "systemctl status weston.service
[ 确定 ] 到达目标图形界面。
开始在 UTMP 中记录运行级别更改...
[ 确定 ] 完成在 UTMP 中记录运行级别更改。
恩智浦 i.MX 发行版 6.6-scarthgap imx8mmevk ttymxc2 imx8mmevk imx8mmevk 登录:
你介意和我分享板启动日志文件和 dts 文件吗?让我仔细检查一下
Re: nxp 6.6.36 kernel for camera ar0144 on iMX8MM board to capture image or videos对不起Re: nxp 6.6.36 kernel for camera ar0144 on iMX8MM board to capture image or videos
@Ahmed230我没有解决办法。你为什么给我贴标签?
Re: nxp 6.6.36 kernel for camera ar0144 on iMX8MM board to capture image or videos@joanie 和@petero5
能和我分享一下解决方案吗?
Re: nxp 6.6.36 kernel for camera ar0144 on iMX8MM board to capture image or videosyocto 6.6.36 内核中的 libtsan 和 libasan 库问题Re: nxp 6.6.36 kernel for camera ar0144 on iMX8MM board to capture image or videos
启动程序:/root/Novus/hello_crash
[使用 libthread_db 启用线程调试]
使用主机 libthread_db 库"/usr/lib/libthread_db.so.1".
程序收到信号 SIGSEGV,分段故障。
0x0000000000000000 in ?? ()
(gdb) bt
#0 0x0000000000000000 in ?? ()
#1 0x0000fffff67b5f3c in dl_iterate_phdr () from /usr/lib/libtsan.so.2
#2 0x0000fffff7996958 in ?? () from /usr/lib/libasan.so.8
#3 0x0000fffff79a51cc in ?? () from /usr/lib/libasan.so.8
#4 0x0000fffff79980b4 in malloc () from /usr/lib/libasan.so.8
#5 0x0000fffff7fc14e4 in malloc (size=56) at /usr/src/debug/glibc/2.39+git/include/rtld-malloc.h:56
#6__GI__dl_exception_create_format (exception=exception@entry=0xfffffffff480, objname=0xfffffff7fe5510"/usr/lib/libtsan.so.2", fmt=fmt@entry=0xfffffff7fdd238"未定义符号:%s%s%s") at dl-exception.c:157
#7 0x0000fffff7fc7550 in _dl_lookup_symbol_x (undef_name=undef_name@entry=0xfffff685fe00"__isoc99_printf", undef_map=undef_map@entry=0xfffff7fe5530、ref=ref@entry=0xfffffffff4e0,
symbol_scope=, version=version@entry=0x0, type_class=0, flags=flags@entry=2, skip_map=skip_map@entry=0xfffffff7fe5530) at dl-lookup.c:809
#8 0x0000fffff639f8c8 in do_sym (handle=, name=0xfffff685fe00"__isoc99_printf", who=0xfffff6842d9c, vers=vers@entry=0x0, flags=flags@entry=2) at dl-sym.c:146
#9 0x0000fffff639fae0 in _dl_sym (handle=, name=, who=) at dl-sym.c:195
#10 0x0000fffff62ed060 in dlsym_doit (a=a@entry=0xfffffffff7c0) at dlsym.c:40
#11 0x0000fffff7fbf458 in__GI__dl_catch_exception (exception=exception@entry=0xfffffffff718, operate=0xfffff62ed040, args=0xfffffffff7c0) at dl-catch.c:237
#12 0x0000fffff7fbf580 in _dl_catch_error (objname=objname@entry=0xfffffffff790, errstring=errstring@entry=0xfffffffff798, mallocedp=mallocedp@entry=0xfffffffff78f, operate=,
args=) at dl-catch.c:256
#13 0x0000ffffffff62eca50 在 _dlerror_run(operate=operate=operate=operate @entry =0xfffff62ed040 ,args=args @entry =0xffffffff7c0)在 dlerror.c: 138
#14 0x0000ffffffff62e0fffffff62c0 在 dlsym_implementation (dl_caller= 已优化 <)
name= ,handle=) 在 >dlsym.c: 54 #15 ___dlsym(handle= ,name= )在 dlsym.c: 68 #16 0x0000ffffff6842d9c 输入??() 来自 /usr/lib/libt san.so.2 #17 0x0000fffffff67e50bc 在??() 来自 /usr/lib/libt san.so.2 #18 0x0000fffffffff6808f94 在??() 来自 /usr/lib/libt san.so.2 #19 0x0000fffffff67af3f8 在??() 来自 /usr/lib/libtsan.so.2 #20 0x0000fffffff67bd4 在 pthread_once () 来自 /usr/lib/libtsan.so.2 #21 0x0000fffff65ca864 在 std:: locale:: facet:: _s_get_c_Locale () () 来自 /usr/lib/libstdc++.so.6 的 #22 064 x0000fffff65fd30 在 std:: ctype:: ctype(无符号短常量*、布尔值、无符号长整型)() 来自 /usr/lib/libstdc++.so.6 #23 0x0000ffff65cb894 在 std:: locale:: _Impl:: _Impl:: _Impl(无符号长整型)() 来自 /usr/lib/lib/libstdc++.so.6 0x0000fffff65cb894 在 std:: locale:: _Impl:: _Impl ++.so.6 #24 0x0000fffffff65cc344 in??() 来自 /usr/lib/lib/libstdc++.so.6 #25 0x0000fffffff65c410 在 std:: locale:: locale () () 来自 /usr/lib/libstdc++.so.6 #26 0x0000fffff65c9384 在 std:: ios_base_library_init () () 来自 /usr/lib/lib/libstdc++.so.6 0x0000fffff65c9384 来自 /usr/lib/lib/libstdc++.so.6 +.so.6 #27 0x0000fffffff65b4620 输入?? () 来自 /usr/lib/libstdc++.so.6 #28 0x0000ffffff7fff7fff7b6c 在 call_init (env=0xffffffffb8,argv=0xffffffba8,argc=1,l=) 中 dl-init.c: 74 #29 call_init (l= < 已优化) 输出 >,argc=1,argv=0xffffffffba8,env=0xfffffffbb8) 在 dl-init.c: 26 #30 0x0000ffffffff7c8c 在 _dl_init (main_map=0xffffffff350,argc=1,argv=0xfffffffff350,argc=1,argv=0xfffffffffff350,argv=0xffffffffffffb8) fba8,env=0xffffffffb8) 在 dl-init.c: 121 #31 0x0000ffffffffffff7ffffff7fffff7ffffff7fffff 在 _start () 中.../sysdeps/aarch64/dl-start.s: 46 (gdb) q 调试 会话处于活动状态。
劣质 1 [进程 1038] 将被杀死。
还是辞职?(y或n) y
Re: nxp 6.6.36 kernel for camera ar0144 on iMX8MM board to capture image or videosgst-用上市,不用发布-1.0v4l2src !video/x-raw,width=640,height=480 !waylandsink
将管道设置为 PAUSED ...
将管道设置为 PAUSED 失败。
正在将管道设置为 NULL...
正在释放管道...
root @imx8mmevk:~# GST_DEBUG=3 gst-用上市-1.0v4l2src !video/x-raw,width=640,height=480 !waylandsink
将管道设置为 PAUSED ...
0:00:00.104761125 700 0xaaaaee7718b0 WARN waylandsink gstwaylandsink.c:473:gst_wayland_sink_find_display:warning:无法初始化 Wayland 输出
0:00:00.104805375 700 0xaaaaee7718b0 WARN waylandsink gstwaylandsink.c:473:gst_wayland_sink_find_display:警告:创建 GstWlDisplay 失败:'连接 wayland di 失败'
将管道设置为 PAUSED 失败。
将管道设置为 NULL ...
释放管道 ...
Re: nxp 6.6.36 kernel for camera ar0144 on iMX8MM board to capture image or videos媒体控制器 API 版本 6.6.36
媒体设备信息
驱动程序 imx7-CSI 型号 imx-media 串行总线信息平台:32e20000.csi-upstream
hw revision 0x0
驱动程序版本 6.6.36
设备拓扑
-实体 1:CSI(2 个键盘,2 个链接,0 条路由)
类型 V4L2 子开发子类型未知标志 0
设备节点名称 /dev/v4l-subdev0 pad0:Sink [stream: 0 fmt: uyvy8_2x8/640x480 字段:无色彩空间:srgb xfer: srgb ycbcr: 601 量化:lim-range] <-" csi8_2x8/640x480 字段:无色彩空间:srgb xfer: srgb ycbcr: 601 量化:lim-range]-csi8_2x8/640s-32e30000.mipi-csi-upstream " :1
[已启用,不可变] p
ad1:来源 [stream: 0 fmt: uyvy8_2x8/640x480 字段:无色彩空间:srgb xfer: srgb ycbcr: 601 量化:lim-
range]
-> " csi capture ": 0 [启用,不可变]
-实体 4:csi 捕获(1 个键盘,1 个链接)
类型节点子类型 V4L 标志 0
设备节点名称 /dev/video0 p
ad0:Sink
<-" csi " :1 [启用,不可变]-实体 10:csis-32e30000.mipi-csi-upstream
(2 个键盘、2 个链接、0 条路线)
设备节点名称 /dev/v4l-subdev1 pad0:Sink
[stream: 0 fmt: uyvy8_1x16/640x480 字段:无 colorspace: smpte170m xfer: 709 ycbcr: 601 量化:lim-range] <-" ds90ub960 3-60 00
30 ": 2 [] pad1:来源 [直播:0 fmt: uyvy8_1x16/640x480 字段:无色彩空间:smpte170m xfer: 709 ycbcr: 601 量化:lim-range]->
" csi ": 0 [已启用,不可变]
-实体 15:ds90ub960 3-0030(3 个键盘、2 个链接、1 条路由)
设备节点名称 /dev/v4l-subdev2 路由:
0/0-> 2/0 [ACTIVY] pad0:Sink [stream: 0 fmt: uyvy8_1x16/640x480 字段:无 space: srgb xfer: srgb ycbcr: 601 量化:lim-range] <-" ds90ub
953 3-0018
" :1 [已启用,不可变] pad1:Sink p
ad2:来源
[stream: 0 fmt: uyvy8_1x16/640x480 @1 /30 字段:无 colorspace: srgb xfer: srgb ycbcr: 601 量化:lim-range]-> " csis-32e30000.mipi-csi-upstream ": 0 []-实体 21: ds90ubcr: lim-range]-csis-32e30000.mipi-csi-upstream: 0 []-实体 21: ds90ubcr: lim-range 953 3-0018(2 个焊盘、2 个链接、1 条路由)类型 V4L2 子开发子类型未知标志 0 设备节点名称 /dev/v4l-subdev3 路由:0/0-
> 1/0 [ACTIVE] p
ad0:Sink
[stream: 0 fmt: uyvy8_1x16/640x480 字段:无色彩空间:srgb xfer: srgb ycbcr: 601 量化:lim-range] <-" ar0144 4-0010 ": 0 [启用,不可变] pad1:来源 [直播:0 fmt: uyvy8_1x16/640xxx8_1x16/640xxx480 字段:无色彩空间:srgb xfer: srgb ycbcr: 601 量化:lim-range]-
>18 " ds90ub960 3-0030 ": 0 [启用,不可变]
-实体 26:ar0144 4-0010(1 个键盘,1 个链接,0 条路线)
类型 V4L2 子开发子类型传感器标志 0 设备节点名称 /dev/v4l-subdev4 pad0:来源 [stream: 0 fmt:y12_1x12/1280x800 @10 /601 字段:无 colorspace: srgb crop.bounds 0,0
) /1296x808
crop:(4,4)/1280x800]
-> " ds90ub953 3-0018":0 [ENABLED,IMMUTABLE]
你能成功从 ar0144 捕获视频吗?比如命令 " gst-launch-1.0v4l2src !video/x-raw,width=640,height=480 !waylandsink"?你能把日志文件发给我吗?你用过和 imx8mm evk 板一样的 ddr 吗?据我所知,如果客户在使用摄像头前不使用 media-ctl 命令,6.12 版就会出现这个问题,但 6.6.36 版应该没问题,所以我需要更详细的信息,同时也请分享您使用"media-ctl -p 时的结果。"
Re: nxp 6.6.36 kernel for camera ar0144 on iMX8MM board to capture image or videosv4l2-ctl-d0--list-formats-ext
ioctl:VIDIOC_ENUM_FMT
类型:视频采集
[0]:'UYVY'(UYVY 4:2:2)尺寸:连续 4x1-65532x65535 [1]:'YUYV'(YUYV 4:2:2)
尺寸:连续 4x1-65532x65535 [2]:'BAYV'(YUYV 4:2:2)'(8 位拜耳 BGBG/GRG)大小:连续 8x1-65528x65535
[3]:' GBRG '(8 位拜耳 GBGB/RGRG)
[4]:' GRBG '(8 位拜耳 GRGR/BGBG)大小:连续 8x1-65528x65535 [5]:' RGB '(8 位拜耳 RGRG/GBGB)
[6]:'BG10
'(10 位拜耳 BGBG/GRGR)
大小:连续 4x1-65532x65535
[7]:' GB10 '(10 位拜耳 GBGB/RGRG)大小:连续 4x1-65532x65535 [8]:' BA10 '(10 位拜耳 GRGR/BGBG)
[9]:'RG10'(10 位拜耳 RGRG/GBGB)大小:连续 4x1-65532x65535 [10]:'BG12'(12 位拜耳 BGBG/GRG)
[11]:'GB12'(12 位拜耳 GBGB/RGRG)尺寸:连续 4x1-65532x65535 [12]: 'BA12'(12 位拜耳 GRGR/BGBG)
大小:连续 4x1-65532x655
35 [13
]: 'RG12'(12 位拜耳 RGRG/GBGB)
大小:连续 4x1-65532x65535 [14]:'BG14'(14 位拜耳 BGBG/GRG)大小:连续 4x1-65532x65535
[15]:'GB14'(14 位拜耳 GBGB/RGRG)
大小:连续 4x1-65532x65535 35
[16]:'GR14'(14 位拜耳 GRGR/BGBG)
大小:连续 4x1-65532x65535 [17]:'RG14'(14 位拜耳 RGRG/GBGB)大小:连续 4x1-65532x65535
[18]:“灰色”(8 位灰度)尺寸:连续 8x1-65528x65535 [19]]: 'Y10 '(10 位灰
度)大小:连续 4x1-65532x655
35 [20]:
'Y12 '(12 位灰度)
[21]:'Y14'(14 位灰度)大小:连续 4x1-65532x65535
能否告诉我 "v4l2-ctl -d0 --list-formats-ext" 的结果?
@joanxie
@joanxie,
GST_DEBUG= 3 gst-用上市-1.0-v v4l2src num-buffers=5 设备=/dev/video0!video/x-raw,format=GRAY8,depth=8,width=1280,height=800 !视频转换 !jpegenc !multifilesink location=ar0144_mono_image.jpg
issue is
将管道设置为正在播放 ...
新时钟:GstSystemClock
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:sink: caps = video/x-raw, format=(string)GRAY8, depth=(int)8, width=(int)1280, height=(int)800, framerate=(fraction)120/1, interlace-mode=(string)proge
其他调试信息:
缓冲池激活失败
0:00:00.015445250 后执行结束
将管道设置为 NULL ...
附加调试信息:
GStreamer 命令完成。
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-21-2025 07:51 AM
更新者:
