2134547_en-US
2134547_en-US
2134547_en-US
Jlink fails to debug imx93
When using JLink to debug the M33 core of i.MX93, after setting breakpoints, it seems only the PC pointer is halted, while various internal counters continue counting, preventing normal debugging. What are the solutions for this issue?Thank you for ansering!
Re: Jlink fails to debug imx93
Yes, and I tried on single M33 core, the system counter can't be halted as before. I can't find the reason.
Best Regards.
Hi @leoX
My test is based on single M33 and Jlink, did you boot M33 with remoteproc?
Zhiming
Thank you for your response! I am reading tstmr in a task to calculate the task's execution cycle, but if I add a breakpoint, the calculated cycle increases, indicating that the system counter continues to count when I add a breakpoint. Also, I am starting the M core through the A core. Does setting the download mode for M33 help?
Best Regards
Can you share the screenshot of  various internal counters?
Did you set the m33 download mode?
Zhiming
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-22-2025 12:02 AM
更新者:
