2134499_en-US
2134499_en-US
2134499_en-US
When I create a Device Tree, I get "Missing #address-cels" in the imx7s.dtsi file
Hello.
The imx7s.dtsi file is included to create the Device Tree.
A warning message appears saying "imx7s.dtsi: Missing #address-cels in interrupt provider".
imx7d.dtsi gives the warning "usbphynop2: missing or empty reg/range property".
  usbphynop2: usbphynop2 {
      compatible = "usb-nop-xceiv";
      clocks = <&clks IMX7D_USB_PHY2_CLK>;
      clock-names = "main_clk";
Why are these warnings appearing if this was made for the SABRE board?
Thank you.
Re: When I create a Device Tree, I get "Missing #address-cels" in the imx7s.dtsi file
You are welcome, any question contact us freely.
Wish you have a nice day
Thank you.
I understand that the warning can be ignored.
I'm still debugging, so I haven't checked the warning part yet.
Anything without warnings is working fine.
If I have any problems debugging the warning part, I'll ask again.
Best regards.
For the warnings you can ignore it, are you met the error in your side?
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-21-2025 09:49 AM
更新者:
