2124635_en-US
2124635_en-US
2124635_en-US
External physical buttons
There are several external physical keys, can the corresponding key events be added inside the gui-guider?
Re: 外部实体按键Hello! May I ask how you solved it? Do you have a tutorial?Re: 外部实体按键
I've done it with reference to the online tutorial, thanks
Re: 外部实体按键
Hi @Cui5222
Which chip do you use?
Harry.
Re: 外部实体按键
Is there a tutorial or reference?
Re: 外部实体按键
Hi @Cui5222
Yes, GUI Guider does support linking external hardware buttons to the GUI, but this usually requires you to design the interface logic in GUI Guider and then manually add the logic for handling external buttons in the generated code.
Harry.
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-21-2025 09:30 AM
更新者:
