2103798_en-US
2103798_en-US
2103798_en-US
S32DS3.4 安装iar插件失败
报错如下:
An error occurred while collecting items to be installed session context was:(profile=DefaultProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=). Problems downloading artifact: osgi.bundle,com.iar.dmgr,1.1.0.202505161156. Error reading signed content:C:\Users\vboxuser\AppData\Local\Temp\signatureFile8984369696384064703.jar An error occurred while processing the signatures for the file: C:\Users\vboxuser\AppData\Local\Temp\signatureFile8984369696384064703.jar Problems downloading artifact: org.eclipse.update.feature,com.iar.dmgr.feature,1.1.0.202505161156. Error reading signed content:C:\Users\vboxuser\AppData\Local\Temp\signatureFile2215016743562443700.jar An error occurred while processing the signatures for the file: C:\Users\vboxuser\AppData\Local\Temp\signatureFile2215016743562443700.jar Problems downloading artifact: osgi.bundle,com.iar.dmgr.jna,3.4.0.202505161156. Error reading signed content:C:\Users\vboxuser\AppData\Local\Temp\signatureFile3084560555014788452.jar An error occurred while processing the signatures for the file: C:\Users\vboxuser\AppData\Local\Temp\signatureFile3084560555014788452.jar Problems downloading artifact: osgi.bundle,com.iar.dmgr.ui,1.1.0.202505161156. Error reading signed content:C:\Users\vboxuser\AppData\Local\Temp\signatureFile5078090908682208579.jar An error occurred while processing the signatures for the file: C:\Users\vboxuser\AppData\Local\Temp\signatureFile5078090908682208579.jar
回复: S32DS3.4 安装iar插件失败
Hi, Chris
I'm currently encountering this problem: installing the IAR plugin on S32DS3.5; the path is the one downloaded from the official website : https://eclipse-update.iar.com/plugin-manager/1.0
After installation and restart, the "IAR EMBEDED workbench plugin manager" option is no longer visible under HELP.
The IAR version is 9.32.2.
The S32DS v3.5 can use the eclipse-iar-arm-8.0 plugin.
For some versions of S32DS (corresponding to different versions of Eclipse), you can try installing the IAR plugin offline.
https://eclipse-update.iar.com/updatesites.html
回复: S32DS3.4 安装iar插件失败3.5 or higher is fine.回复: S32DS3.4 安装iar插件失败Okay, could you tell me which version can install the IAR plugin?回复: S32DS3.4 安装iar插件失败I asked about it a while ago, and it turns out that the IAR plugin upgrade doesn't support older versions of Eclipse.
No ratings
Version history
Last update:
13 hours ago
Updated by:
