2082672_en-US
2082672_en-US
2082672_en-US
How can i enable CMAC, UID, COUNTER and RAND in NTAG424 DNA?
I'm trying to use the newest Android SDK library to set my dynamic URL based on AES key, but I'm unable to do it.
nxpnfcandroidlib-release-protected.aar
This is my code
override fun onNewIntent(intent: Intent) {
	Log.i("NFC", "Intent action: ${intent.action}")
	super.onNewIntent(intent)
	Log.i("MainActivity", "NFC tag discovered")
	val cardType = libInstance.getCardType(intent)
	Log.i("MainActivity", "Detected card type: $cardType")
	if (cardType == CardType.NTAG424DNA) {
	    val ntag424DNA: INTAG424DNA = DESFireFactory.getInstance().getNTAG424DNA(libInstance.customModules)
	    val reader: IReader = ntag424DNA.reader
	    try {
	        if (!reader.isConnected) {
	            reader.connect()
	        ntag424DNA.isoSelectApplicationByDFName(NTAG424DNA_APP_NAME)
	        Log.i("NFC", "ISO selected app by DF Name ")
	        authenticateTag(ntag424DNA, KEY_AES128_DEFAULT)
		    creatingNDEFmessage(ntag424DNA)
		    changeFileSettings(ntag424DNA, 0x01)
	        ntag424DNA.setPICCConfiguration(true)
	        Log.i("MainActivity", " PICC Configuration updated to enable SDM globally.")
	        changeSDMFileSettings(ntag424DNA, 0x01)
	        if (reader.isConnected) {
	            reader.close()
	    } catch (e: Exception) {
	        e.printStackTrace()
private fun creatingNDEFmessage(ntag424DNA: INTAG424DNA) {
    // 1. Creating URI NDEF message
    val msg = NdefMessageWrapper(
        NdefRecordWrapper(
            NdefRecordWrapper.TNF_ABSOLUTE_URI,
            "https://domain.com?uid=04BB38D2AA1191&ctr=0001&cmac=3ab665b76b795cb9bf76a17956cc9fb3&rand=422def08-8a1c-49c9-9138-434cde858faa".toByteArray(
                Charset.forName("US-ASCII")
            ), ByteArray(0), ByteArray(0)
    ntag424DNA.writeNDEF(msg);
    Log.i("MainActivity", "URI NDEF message written successful ")
    val ndefRead = ntag424DNA.readNDEF()
    Log.i("MainActivity", "Read URI NDEF message ${CustomModules.getUtility().dumpBytes(ndefRead.toByteArray())}")
private fun changeFileSettings(ntag424DNA: INTAG424DNA, fileNumber: Int) {
    // 3. Create NTAG 424 DNA file settings for E104
    val fileSettings = NTAG424DNAFileSettings(
        MFPCard.CommunicationMode.Encrypted,    // = 0x03 = Full ENC + CMAC (SUN)
        0x0E.toByte(),             // Read access = key slot 0x00 maybe 0x01
        0x0E.toByte(),             // Write access = always
        0x0E.toByte(),             // RW access = always
        0x0E.toByte()              // Change access = always
    Log.i("MainActivity", "Prepare for saving changes in file $fileNumber")
    ntag424DNA.changeFileSettings(fileNumber, fileSettings)
    Log.i("NFC", " File settings updated $fileNumber")
private fun changeSDMFileSettings(ntag424DNA: INTAG424DNA, fileNumber: Int) {
    val fileSettings = ntag424DNA.getFileSettings(fileNumber);
    fileSettings.isSDMEnabled = true;
    fileSettings.isUIDMirroringEnabled = true;
    fileSettings.piccDataOffset = intTo2ByteArray(51)
    fileSettings.sdmMacOffset = intTo2ByteArray(51)
    fileSettings.sdmMacInputOffset = intTo2ByteArray(51)
    fileSettings.sdmReadCounterOffset = intTo2ByteArray(51)
    fileSettings.uidOffset = intTo2ByteArray(51)
    fileSettings.sdmAccessRights = byteArrayOf(0x00, 0x00)
    Log.i("MainActivity", "Prepare for saving SDM changes in file $fileNumber")
    Log.i("NFC", " File settings updated: SUN CMAC enabled on $fileNumber")
private fun intTo2ByteArray(value: Int): ByteArray {
    return byteArrayOf(
        ((value shr  and 0xFF).toByte(),
        (value and 0xFF).toByte()
I know that the offset number doesn't match the position in the URL but whatever I'm changing, I'm still getting this error. It looks like, for some reason, these settings can not be saved by this method.
This is the error message
com.nxp.nfclib.exceptions.UsageException: Invalid Parameters! {Invalid Value for PICC Offset}
Code examplesRe: How can i enable CMAC, UID, COUNTER and RAND in NTAG424 DNA?
The issue was due to the wrong offset value. It seems ntag reserved 21 default index. Now we are trying to change factory 128 aes key and changekey() function didnt work for us
@ukcas
hey there,
I am following this thread to set up JSON data, but it is not working for me. This is my first time working with hardware, which is making things much more challenging. I am using the NXP Android library and the sample Android application from here: https://www.nxp.com/design/design-center/software/rfid-developer-resources/taplinx-software-developm...
Below is my code inside Sample_Application_Android/src/main/java/com/nxp/sampletaplinx/WriteActivity.java
public static byte[] intTo2ByteArray(int value) {
    return new byte[] {
            (byte) (value & 0xFF),        // LSB
            (byte) ((value >> 8) & 0xFF), // middle byte
            (byte) ((value >> 16) & 0xFF) // MSB
private void tag424DNACardLogic(INTAG424DNA ntag424DNA) {
    byte[] KEY_AES128_DEFAULT = new byte[] {
            (byte)0x00, (byte)0x00, (byte)0x00, (byte)0x00,
    byte[] NTAG424DNA_APP_NAME =
            {(byte) 0xD2, (byte) 0x76, 0x00, 0x00, (byte) 0x85, 0x01, 0x01};
    byte[] data ={ 0x73, 0x75, 0x73, 0x68, 0x69, 0x6C };
    mStringBuilder.append("\n\n");
    int timeOut = 2000;
    try {
        ntag424DNA.isoSelectApplicationByDFName(NTAG424DNA_APP_NAME);
        KeyData aesKeyData = new KeyData();
        Key keyDefault = new SecretKeySpec(KEY_AES128_DEFAULT, "AES");
        aesKeyData.setKey(keyDefault);
       ntag424DNA.authenticateEV2First(0, aesKeyData, null);
        mStringBuilder.append(getString(R.string.Authentication_status_true));
        ntag424DNA.setPICCConfiguration(true);
        String jsonTemplate = "{\"uuid\":\"00000000000000\",\"counter\":\"000000\",\"cmac\":\"0000000000000000\",\"domain1\":" + 1 + ",\"domain2\":" + 1 + "}";
        byte[] jsonBytes = jsonTemplate.getBytes("UTF-8");
        NTAG424DNAFileSettings fs = new NTAG424DNAFileSettings(
                CommunicationMode.Plain,  // or MAC/ENC depending on your security
                (byte) 0x0E, // Read access: Key 0
                (byte) 0x0E, // Write access: Key 0
                (byte) 0x0E, // Read/Write: Key 0
                (byte) 0x00  // Change access: Free
        byte[] type = "U".getBytes("US-ASCII");
        fs.setSDMEnabled(true);
        fs.setUIDMirroringEnabled(true);
        fs.setSDMReadCounterEnabled(true);
        byte[] bytes = new byte[] { (byte)0xE0, (byte)0x00, (byte)0x00 };
        fs.setSdmAccessRights(bytes);
        byte[] uuidOffset = intTo2ByteArray(8);
        fs.setUidOffset(uuidOffset);
        byte[] readCounterOffset = intTo2ByteArray(35);
        fs.setSdmReadCounterOffset(readCounterOffset);
        byte[] macOffset = intTo2ByteArray(51);
        fs.setSdmMacInputOffset(uuidOffset);
        fs.setSdmMacOffset(macOffset);
        ntag424DNA.changeFileSettings(FILE_NUMBER, fs);
        // Create NDEF record
        NdefRecordWrapper record = new NdefRecordWrapper(
                NdefRecordWrapper.TNF_WELL_KNOWN,
                type,
                new byte[0],  // empty ID
                jsonBytes     // payload (your JSON)
        // Wrap record into NDEF message
        NdefMessageWrapper msg = new NdefMessageWrapper(record);
        NxpLogUtils.save();
    } catch (Exception e) {
        writeFailedMessage();
        mStringBuilder.append(e.getMessage());
        Log.i("MainActivity", "URI NDEF message written successful $msg " + e.getMessage()  );
        showMessage(mStringBuilder.toString(), PRINT);
        NxpLogUtils.save();
 would be great help if someone can assist me with this
Thanks for the help! You are right that my offset has the wrong values. This is what I have changed and now I can save settings.
        try {
                reader.connect()
            authenticateTag(0x00, ntag424DNA, KEY_AES128_DEFAULT)
            changeFileSettings(ntag424DNA, 0x02)
                reader.close()
            Log.e("MainActivity", e.localizedMessage ?: "No Error Message");
            e.printStackTrace()
        MFPCard.CommunicationMode.Plain,    // = 0x03 = Full ENC + CMAC (SUN)
        0x00.toByte()              // Change access = always
    fileSettings.isSDMReadCounterEnabled = true
    fileSettings.sdmAccessRights = byteArrayOf(0xfe.toByte(), 0xe1.toByte())
    fileSettings.uidOffset = byteArrayOf(0x1A, 0x00, 0x00)
    fileSettings.sdmReadCounterOffset = byteArrayOf(0x2d, 0x00, 0x00)
    fileSettings.sdmMacOffset = byteArrayOf(0x39, 0x00, 0x00)
    fileSettings.sdmMacInputOffset = byteArrayOf(0x39, 0x00, 0x00)
    Log.i("MainActivity", " File settings updated $fileNumber")
    val payload = byteArrayOf(0x04) + "noexample.xxxx?uid=00000000000000&ctr=000000&cmac=0000000000000000".toByteArray()
        NdefRecordWrapper(
            "U".toByteArray(StandardCharsets.US_ASCII),
            ByteArray(0),
            payload
Dear Rocky2,
Please check document refered by jimmyvhan and datasheet.
Your offsets are overlapping, which is not permitted as per datasheet.
Considering your desired URL. You have too less space for NFCCounter, which is 3 bytes. So below settings are suiting corrected URL.
https://domain.com?uid=04BB38D2AA1191&ctr=000001&cmac=3ab665b76b795cb9bf76a17956cc9fb3&rand=422def08...
 You shall use these parameters for SDM Configuration. You decide on Input data for CMAC calculation as well. We used UIDOffset as starting point for this example.
fileSettings.sdmMacOffset = intTo2ByteArray(53)
fileSettings.sdmMacInputOffset = intTo2ByteArray(22)
fileSettings.sdmReadCounterOffset = intTo2ByteArray(41)
fileSettings.uidOffset = intTo2ByteArray(22)
TapLinx team
This document could be useful for you.
NTAG 424 DNA and NTAG 424 DNA TagTamper features and hints
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-21-2025 09:05 AM
更新者:
