In eFlexPWM peripheral, is it possible to generate a single PWM cycle, but without using the reload interrupt to finish the cycle?
Thanks in advance
Hi @zorrotz,
Thanks for the clarifications. After looking into it, I have arrived at the conclusion that the only way of doing single PWM pulses is indeed by using the reload interruption.
BR,
Edwin.
Hi @EdwinHz ,
My part number is MKV46F128VLL16.
The IDE version is MCUXpresso IDE v11.9.0 [Build 2144] and the SDK is 2.8.0.
Hi @zorrotz,
Could you please share what your part number is, as well as the SDK and IDE versions that you are using?
BR,
Edwin.
