2065738_en-US
2065738_en-US
2065738_en-US
Help with ECDSA Verification in LPC55S28 Bootloader (32KB Size Limit)
Hello NXP Community,
I'm developing a secure bootloader for the LPC55S28 and have run into a significant code size issue when implementing ECDSA signature verification.
Current Issue
My bootloader needs to verify ECDSA P-256 signatures, and it must fit within a 32KB flash region. When using mbedTLS for ECDSA verification (even with a minimal configuration that only enables ECDSA), my code size explodes from approximately 13KB to 56KB:
Spoiler
Name Run address Load address Size Type
.text 0x0 n/a 56412 section
mpi_mul_hlp 0x9ae2 n/a 6388 local function
ecp_mod_p256 0x839c n/a 2032 local function
shiftleft 0x2bd0 n/a 1792 local function
MultprecCiosMul521_ct 0x4fdc n/a 1772 local function
shiftright 0x2514 n/a 1724 local function
double_scalar_multiplication 0x3fb4 n/a 1580 global function
MultprecCiosMul_ct 0x1b4c n/a 1444 local function
mbedtls_mpi_div_mpi 0xb69c n/a 1316 global function
mbedtls_mpi_inv_mod 0xbdfa n/a 1090 global function
precompute_double_scalar_LUT16 0x3aac n/a 1084 local function
invert_mod_p384 0x4884 n/a 1062 local function
ecp_double_jac 0x7d6c n/a 972 local function
ecp_add_mixed 0xac8 n/a 912 local function
mbedtls_ecp_muladd_restartable 0xea8 n/a 868 global function
Jac_addition 0x33ec n/a 776 global function
StrFormatPrintf 0x735c n/a 700 global function
invert_mod_p521 0x4d14 n/a 616 local function
invert_mod_p256 0x45e0 n/a 576 local function
verify_ecdsa_signature 0x4a4 n/a 544 local function
Jac_add_affine 0x36f4 n/a 536 global function
ecdsa_verify_restartable 0x12c0 n/a 504 local function
USART_Init 0x6404 n/a 460 global function
mbedtls_mpi_gcd 0xbc4a n/a 432 global function
CASPER_montadd 0x21f0 n/a 428 local function
hashcrypt_sha_process_message_data 0x5ddc n/a 420 local function
Jac_double 0x390c n/a 416 global function
USART_SetBaudRate 0x6650 n/a 396 global function
mbedtls_mpi_mul_mpi 0xb3d6 n/a 382 global function
CLOCK_SetFLASHAccessCyclesForFreq 0x5888 n/a 380 global function
__aeabi_uldivmod 0xd048 n/a 372 global function
mbedtls_mpi_add_abs 0x96ba n/a 366 global function
read_and_verify_toc 0x6c4 n/a 364 local function
CASPER_ECC_SECP521R1_MulAdd 0x19f4 n/a 344 global function
CASPER_half 0x239c n/a 340 local function
lowpower_set_system_voltage 0x6024 n/a 340 local function
mbedtls_mpi_shift_l 0x91bc n/a 330 global function
mbedtls_mpi_sub_abs 0x98ba n/a 326 global function
CASPER_ECC_SECP256R1_MulAdd 0x179c n/a 324 global function
DbgConsole_Init 0x2b0 n/a 312 global function
mbedtls_mpi_shift_r 0x9306 n/a 310 global function
mbedtls_mpi_cmp_mpi 0x9540 n/a 310 global function
__Vectors 0x0 n/a 304 global object
g_pfnVectors 0x0 n/a 304 global object
CASPER_ECC_SECP384R1_MulAdd 0x18e0 n/a 276 global function
HAL_UartInitCommon 0x68cc n/a 272 local function
mbedtls_mpi_cmp_abs 0x943c n/a 260 global function
CASPER_montsub 0x20f0 n/a 256 local function
CASPER_MEMCPY 0x14e0 n/a 252 global function
fseek 0x6d50 n/a 248 global function
ecp_normalize_jac 0x7c78 n/a 244 local function
hashcrypt_sha_finalize 0xc5e2 n/a 238 local function
lowpower_set_dcdc_power_profile 0x6178 n/a 236 local function
mbedtls_mpi_copy 0x8cf6 n/a 210 global function
ecp_modp 0x9f8 n/a 208 local function
HASHCRYPT_SHA_Update 0xc7ac n/a 208 global function
precompute_double_scalar_LUT4 0x3ee8 n/a 204 local function
mbedtls_ecp_point_read_binary 0x930 n/a 200 global function
malloc 0x6b2c n/a 200 global function
mbedtls_mpi_write_binary 0x90f4 n/a 200 global function
ConvertRadixNumToString 0x7208 n/a 194 local function
HASHCRYPT_SHA_Finish 0xc87c n/a 184 global function
mbedtls_int_div_int 0xb5e8 n/a 180 local function
mbedtls_ecp_fix_negative 0x82f0 n/a 172 local function
lowpower_set_voltage_for_process 0xc934 n/a 170 local function
Jac_toAffine 0x3348 n/a 164 global function
HASHCRYPT_DriverIRQHandler 0x5f80 n/a 164 global function
ecp_group_load 0x81c2 n/a 162 local function
CLOCK_AttachClk 0x56e8 n/a 160 global function
add_sub_mpi 0x9a00 n/a 156 local function
mbedtls_ecp_group_free 0x7966 n/a 152 global function
lowpower_get_part_process_corner 0x6264 n/a 148 local function
mbedtls_mpi_mul_int 0xb554 n/a 148 global function
derive_mpi 0xc23c n/a 148 local function
mpi_sub_hlp 0x9828 n/a 146 local function
casper_select 0x15dc n/a 144 local function
hashcrypt_get_data 0xc454 n/a 144 local function
USART_WriteBlocking 0x67dc n/a 140 global function
PrintGetPrecision 0x6fba n/a 140 local function
mbedtls_mpi_mod_mpi 0xbbc0 n/a 138 global function
mbedtls_ecp_group_load 0x1238 n/a 136 global function
main 0x8ac n/a 132 global function
mbedtls_mpi_grow 0x8c1c n/a 132 global function
CLOCK_SetClkDiv 0x5788 n/a 128 global function
CLOCK_SetupFROClocking 0x5808 n/a 128 global function
USART_GetDefaultConfig 0x65d0 n/a 128 global function
mbedtls_ecp_group_init 0x7888 n/a 126 global function
jump_to_application 0x830 n/a 124 local function
mbedtls_mpi_read_binary 0x907a n/a 122 global function
CASPER_ecc_init 0x166c n/a 120 global function
multiply_casper 0x32d0 n/a 120 local function
_initio 0x6bf4 n/a 120 global function
FLEXCOMM_SetPeriph 0xc3e0 n/a 116 local function
CASPER_ECC_equal 0x16e4 n/a 112 global function
_Cwritebuf 0x6ca8 n/a 108 global function
hashcrypt_sha_one_block 0xc576 n/a 108 local function
PrintGetWidth 0x6f50 n/a 106 local function
DbgConsole_Vprintf 0x3e8 n/a 104 global function
toMontgomery_ECC_P384 0x4cac n/a 104 local function
mbedtls_mpi_bitlen 0x8f30 n/a 104 global function
_fdopen 0xcee2 n/a 104 global function
DbgConsole_PrintCallback 0x6ebe n/a 102 local function
mbedtls_mpi_lsb 0x8e88 n/a 102 global function
mpi_bigendian_to_host 0x9014 n/a 102 local function
ResetISR 0x180 n/a 100 global function
toMontgomery_ECC_P256 0x4820 n/a 100 local function
SystemInit 0x6868 n/a 100 weak function
HAL_UartSendBlocking 0x69dc n/a 100 global function
FLEXCOMM_PeripheralIsPresent 0xc37c n/a 100 local function
mbedtls_ecp_copy 0x7a48 n/a 98 global function
toMontgomery_ECC_P521 0x4f7c n/a 96 local function
RESET_ClearPeripheralReset 0x63a4 n/a 96 global function
mbedtls_mpi_sub_mod 0x7b64 n/a 96 local function
SerialManager_Init 0xcb56 n/a 96 global function
SerialManager_OpenReadHandle 0xcc06 n/a 96 global function
reverse_array 0x8138 n/a 94 local function
HASHCRYPT_SHA 0xc6fe n/a 94 global function
FLEXCOMM0_DriverIRQHandler 0x5aa0 n/a 92 global function
FLEXCOMM1_DriverIRQHandler 0x5afc n/a 92 global function
FLEXCOMM2_DriverIRQHandler 0x5b58 n/a 92 global function
FLEXCOMM3_DriverIRQHandler 0x5bb4 n/a 92 global function
FLEXCOMM4_DriverIRQHandler 0x5c10 n/a 92 global function
FLEXCOMM5_DriverIRQHandler 0x5c6c n/a 92 global function
FLEXCOMM6_DriverIRQHandler 0x5cc8 n/a 92 global function
FLEXCOMM7_DriverIRQHandler 0x5d24 n/a 92 global function
FLEXCOMM8_DriverIRQHandler 0x5d80 n/a 92 global function
RESET_SetPeripheralReset 0x6348 n/a 92 global function
mbedtls_mpi_add_mod 0x7bc4 n/a 92 local function
mbedtls_mpi_lset 0x8dea n/a 92 global function
BOARD_BootClockFROHF96M 0x6a98 n/a 88 global function
mbedtls_mpi_shift_l_mod 0x7c20 n/a 88 local function
fclose 0xcf9c n/a 88 global function
mbedtls_mpi_resize_clear 0x8ca0 n/a 86 local function
DbgConsole_SendDataReliable 0x25c n/a 84 global function
calculate_sha256 0x450 n/a 84 local function
mbedtls_ecp_set_zero 0x7aaa n/a 82 global function
_fflush 0xcf4a n/a 82 global function
ecp_add 0xe58 n/a 80 global function
FLEXCOMM_Init 0x5a50 n/a 80 global function
POWER_SetVoltageForFreq 0x62f8 n/a 80 global function
HASHCRYPT_SHA_Init 0xc75c n/a 80 global function
SerialManager_OpenWriteHandle 0xcbb6 n/a 80 global function
calloc 0xcdc6 n/a 80 global function
strlen 0xce54 n/a 78 global function
FLEXCOMM_GetInstance 0x5a04 n/a 76 global function
mbedtls_mpi_free 0x8bd0 n/a 76 global function
CASPER_ECC_equal_to_zero 0x1754 n/a 72 global function
mpi_uint_bigendian_to_host_c 0x8fb4 n/a 72 local function
add32 0x8264 n/a 70 local function
sub32 0x82aa n/a 70 local function
ftell 0x6e48 n/a 68 global function
PrintOutputdifFobpu 0x70aa n/a 68 local function
PrintOutputxX 0x70ee n/a 68 local function
mbedtls_mpi_cmp_int 0x9676 n/a 68 global function
SerialManager_Write 0xcb12 n/a 68 local function
mbedtls_mpi_get_bit 0x8e46 n/a 66 global function
mbedtls_clz 0x8eee n/a 66 local function
PrintGetRadixFromobpu 0x71c8 n/a 64 local function
mbedtls_mpi_mul_mod 0x7b24 n/a 64 local function
_deferredlazyseek 0xcea2 n/a 64 global function
_do_fflush 0xd008 n/a 64 global function
toc_verification_key 0xda84 n/a 64 local object
PrintFilterLengthFlag 0x718a n/a 62 local function
Serial_UartInit 0xcc86 n/a 62 global function
setvbuf 0xce16 n/a 62 global function
BOARD_InitDEBUG_UARTPins 0x6af0 n/a 60 global function
_sbrk 0x6c6c n/a 60 global function
fflush 0x6d14 n/a 60 global function
hashcrypt_sha_check_input_args 0xc53a n/a 60 local function
BOARD_InitDebugConsole 0x6a40 n/a 56 global function
PrintIsobpu 0x7046 n/a 56 local function
USART_EnableContinuousSCLK 0xc9fa n/a 56 local function
SerialManager_StartWriting 0xcada n/a 56 local function
Serial_UartWrite 0xccc4 n/a 56 global function
HardFault_Handler 0x77f8 n/a 54 global function
HAL_UartInit 0xca62 n/a 54 global function
mbedtls_ecp_point_free 0x7932 n/a 52 global function
mbedtls_ecp_keypair_free_o 0x79fe n/a 52 global function
__aeabi_lowlevel_memset 0xd1f2 n/a 50 global function
mbedtls_ecdsa_verify 0xc2e8 n/a 48 global function
CLOCK_EnableClock 0xc34c n/a 48 local function
free 0xcd96 n/a 48 global function
mbedtls_ecp_get_type 0x782e n/a 46 global function
IOCON_PinMuxSet 0xcd46 n/a 46 local function
__assertion_failed 0x230 n/a 44 global function
ecp_mpi_set1 0x120c n/a 44 local function
DbgConsole_Printf 0x6f24 n/a 44 global function
PrintIsdi 0x707e n/a 44 local function
PrintIsfF 0x7132 n/a 44 local function
PrintIsxX 0x715e n/a 44 local function
mbedtls_ecp_point_init 0x785c n/a 44 global function
mbedtls_ecp_keypair_init 0x7906 n/a 44 global function
ecp_mpi_load 0x8196 n/a 44 local function
hashcrypt_engine_init 0xc4e4 n/a 44 local function
hashcrypt_sha_check_input_alg 0xc510 n/a 42 local function
__aeabi_memcpy4 0xd1c8 n/a 42 global function
__aeabi_memcpy8 0xd1c8 n/a 42 global function
mbedtls_platform_zeroize 0x14b8 n/a 40 global function
mbedtls_ecp_is_zero 0x7afc n/a 40 global function
StrFormatExaminedi 0x72ca n/a 38 local function
StrFormatExaminexX 0x72f0 n/a 38 local function
StrFormatExamineobpu 0x7316 n/a 38 local function
mbedtls_mpi_init 0x8baa n/a 38 global function
casper_get_word 0x24f0 n/a 36 local function
mbedtls_mpi_sub_mpi 0x9abe n/a 36 global function
s_flexcommBaseAddrs 0xdbd8 n/a 36 local object
s_flexcommResets 0xdc10 n/a 36 local object
mpi_sint_abs 0x8dc8 n/a 34 local function
mbedtls_mpi_add_mpi 0x9a9c n/a 34 global function
HAL_UartGetStatus 0xca40 n/a 34 local function
DisableGlobalIRQ 0xca98 n/a 34 local function
POWER_DisablePD 0x56c8 n/a 32 local function
ConvertPrecisionWidthToLength 0x733c n/a 32 local function
EnableGlobalIRQ 0xcaba n/a 32 local function
SerialManager_WriteBlocking 0xcc66 n/a 32 global function
secp256r1_p 0xdac4 n/a 32 local object
secp256r1_a 0xdae4 n/a 32 local object
secp256r1_b 0xdb04 n/a 32 local object
secp256r1_gx 0xdb24 n/a 32 local object
secp256r1_gy 0xdb44 n/a 32 local object
secp256r1_n 0xdb64 n/a 32 local object
s_UsartAdapterBase 0xdc34 n/a 32 local object
data_init 0x1e8 n/a 30 global function
mbedtls_mpi_zeroize 0x8b8c n/a 30 local function
mbedtls_ecdsa_free 0xc32e n/a 30 global function
mbedtls_mpi_size 0x8f98 n/a 28 global function
RESET_PeripheralReset 0xc9de n/a 28 global function
fsl_assert_hook 0x6ea4 n/a 26 weak function
__check_heap_overflow 0x6e8c n/a 24 global function
mpi_uint_bigendian_to_host 0x8ffc n/a 24 local function
mbedtls_ecdsa_can_do 0xc2d0 n/a 24 global function
hashcrypt_save_running_hash 0xc6d0 n/a 24 local function
mbedtls_ecp_keypair_free 0x7a32 n/a 22 global function
mbedtls_ecdsa_init 0xc318 n/a 22 global function
hashcrypt_restore_running_hash 0xc6e8 n/a 22 local function
remove 0xcff4 n/a 20 global function
bss_init 0x206 n/a 18 global function
s_flexcommClocks 0xdbfc n/a 18 local object
SystemInitHook 0xca32 n/a 14 weak function
BOARD_InitPeripherals 0xccfc n/a 14 global function
__main 0xcd80 n/a 14 global function
BOARD_InitBootPeripherals 0xcd0a n/a 12 global function
BOARD_InitBootPins 0xcd74 n/a 12 global function
__aeabi_memcpy 0xd1be n/a 10 global function
As far as I know, the CASPER  can't perform ECDSA verification on its own - it seems to require mbedTLS as a wrapper, which brings in all the additional code.
I've deactivated almost everything in the ksdk_mbedtls_config.h file.
Questions
  1. Is there a way to use the CASPER hardware directly for ECDSA verification without the mbedTLS overhead?
  2. Are there any ROM-based cryptographic functions in the LPC55S28 that could handle ECDSA verification?
  3. Does anyone have a minimal implementation of ECDSA P-256 verification for the LPC55S28 that could fit within my 32KB constraint?
  4. Are there alternatives to mbedTLS with a smaller footprint?
Re: Help with ECDSA Verification in LPC55S28 Bootloader (32KB Size Limit)
This ticket was handled via email due to an issue with the community platform at that time.
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎07-02-2026 04:31 AM
更新者:
