hi ,
we have a issue in CAN reception where we are using two 32bit filters and the masks for RTR bit i.e mask register 3 and 7 are set to 0xFF still we are not able to receive the Extended id with RTR bit set.
You can take as reference the document Using MSCAN on KE16Z MCU (AN12355) where you can find information regarding the two 32-bit identifier filters and extended data frame with a specific identifier,
Also, you can find the KEA128 MSCAN driver from the following link
