2059283_en-US
2059283_en-US
2059283_en-US
S32 Design Studio for ARM Version: 2.2
版本:2.2
为什么相同的代码,编译出来的十六进制文件不一样
Re: S32 Design Studio for ARM Version: 2.2The specific reason has been found, the SDK package added useless definitions resulting in inconsistent file sizes, thank you for your answerRe: S32 Design Studio for ARM Version: 2.2
Hi @JXLIN
Would it be possible for you to share both projects with me? I would like to compare them to ensure there are no differences that might be causing the generation of different hex files.
Hi @JXLIN
To help us better understand the issue, could you provide a bit more detail? Specifically, we would like to know if the problem is happening only with your application or if you are seeing the same behavior with other applications as well.
This will give us a better context of the situation and help us analyze the root cause of this behavior.
BR, VaneB
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-21-2025 02:17 PM
更新者:
