2056482_en-US
2056482_en-US
2056482_en-US
MPX5010DP Sensitivity to sensor orientation
I am currently using a MPX5010DP for a pitot tube project with an Arduino microprocessor and I am finding that the sensor output is sensitive to the sensor orientation.  Sometimes a vertical orientation of the sensor gives stable values, other times a horizontal orientation gives more stable values - it is not consistent.
Does anybody have any further information on sensor orientation.
Thanks.
#MPX5010DP #sensor-orientation
Re: MPX5010DP Sensitivity to sensor orientation
Hi md63
These devices are very sensitive to any change. To ensure optimal performance, we recommend implementing auto-zero according to the application note, This process ensures a “start from Zero” and the measures will be more stable, as linked below:
Implementing Auto-Zero for Integrated Pressure Sensors
I hope this information has helped you, please let me know if you need help with anything else.
Have a great day and best of luck.
No ratings
Version history
Last update:
‎02-04-2026 10:14 AM
Updated by:
