2054311_en-US
2054311_en-US
2054311_en-US
imx8plus dsp
Hello, nxp developers
Can anyone confirm that hifi4 dap can be used as common dsp? I want use it for sensor data calculation.
By the way, can uart be sxtended?We need 5 uart, but 8mplus datasheet say there are only 4.
thanks!
i.MX 8 Family | i.MX 8QuadMax (8QM) | 8QuadPlusi.MX 8M | i.MX 8M Mini | i.MX 8M Nanoi.MX8ULPRe: imx8plus dspThank you very much for your reply. We will take a detailed look at the PDF.Sincere thanks.Re: imx8plus dsp
Thank you for your interest in NXP Semiconductor products,
DSPs are used through their firmware, please refer to https://www.nxp.com/docs/en/user-guide/IMX_DSP_USERS_GUIDE.pdf.
I found the chapter about NatureDSP Library Support, is the library that matches the common operations of a DSP.
Used signal processing functions: FFT, FIR, vector, matrix, and common mathematics.
For UART expansion, you could either look for multiplexer/bridges or simulate a UART from GPIO, that development would be up to you.
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-21-2025 10:56 PM
更新者:
