EB tresos version: EB tresos Studio 29.0
RTD version: SW32K1_S32M24x_RTD_R21-11_2.0.0_QLP1
The import routine path is as follows:
NXP\SW32K1_S32M24x_RTD_R21-11_2.0.0_QLP1\eclipse\plugins\Dio_TS_T40D2M20I0R0\examples\EBT\S32K1\Dio_Example_S32K144
Thank you very much for your answer, as you said, although the verification project will report an error, but the function of generating code is normal, I can get the code generated by the routine; I'm going to try to compile the generated code next, and hopefully everything goes well.
