Hi:
Question: Is there a limit to the number of SWT overflows?
I would like to ask some questions about SWT. The situation I have encountered now is that I do not feed the dog to SWT, but after the program is reset by SWT for 15 times each time, the development board will be in a state of constant reset, and only after the development board is restarted can it be run again. For this limit of times, is there a corresponding register that can be checked? I am a novice, read for a long time without the relevant description, finally my English is very poor, hope someone can help me.
thank you
Thank you so much, Peter, for solving my problem.
Mir Xu-2024
There is no such limit, if you do not set it in SWT Control Register (SWTx_CR):
Ok, that is clearly enabled destructive reset escalation on default 0xF.
Peter
This is my configuration
