2044216_en-US
2044216_en-US
2044216_en-US
flex-builder building opencv with aruco libs
I am trying to build the libopencv-aruco, which typically comes with new version of OpenCV. When I run bld -c opencv, I don't see this libs being built.
Can anyone provide some guidance on how I could use flex-builder to build the aruco libs?
Re: flex-builder building opencv with aruco libs
In your LSDK 21.08 host build environment, please execute the following command:
$ sudo chroot build/rfs/rootfs_lsdk2108_ubuntu_main_arm64/
Then run the following command.
/# apt-get install libopencv-dev
/# exit
You will get
build/rfs/rootfs_lsdk2108_ubuntu_main_arm64/usr/lib/aarch64-linux-gnu/libopencv_aruco.so.4.2.0
build/rfs/rootfs_lsdk2108_ubuntu_main_arm64/usr/lib/aarch64-linux-gnu/libopencv_aruco.a
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-22-2025 05:55 AM
更新者:
