After upgrading the board to a new firmware and adapting the application (APP_INFO, new SDK/API), the device remains in HostIF BKP (0x401504 bkpt 0xFF).
Flashing the application was initially possible. Debugging (SWD) works, but I get an exception when I try to call NDP functions (debugger only shows ?? for this memory). Re-flashing with Lauterbach script is now also not possible (the memory for the flash driver also shows ??). But I can still attach and debug the currently flashed application.
My guess is that the new application cannot be found and the device has now activated SWUP?
I'm not quite sure why flashing the new application didn't work and how I should proceed from here?
Stefan
Hope you are doing well. Sorry for the inconvenience this might cause you but as the information of this product it's under NDA (Non-Disclosure Agreement) the information it's not public.
For more information about the chip could you please contact one of our distributors available in the Distributor Network|NXP? Or if you have any direct contact, please contact them.
Ricardo
