2034165_en-US
2034165_en-US
2034165_en-US
I2C read and write using s32k144 MBD toolbox
I am using s32k144 to read and write data from an external EEPROM. I will attach the model below. I am able to write the data but the read returns 255+NACK as output. Am i missing something here
Is there a way to specify the register address of the EEPROM in the I2Cmaster block
Can you guys help me out with this issue.
Re: I2C read and write using s32k144 MBD toolbox
I am also facing the same issue with I2C communication using the S32K144 as the master and the ST M24C04 EEPROM as the slave.
Since you are using the same microcontroller and EEPROM, I wanted to check whether you were able to find a solution. If you have resolved this issue, could you please share the solution or let me know what fixed it?
Thank you in advance for your help.
I m using M24C02-DRE EEPROM
标记 (1)
无评分
版本历史
最后更新:
星期五
更新人:
