2028321_en-US
2028321_en-US
2028321_en-US
imx8mm with 24-Bit RGB TTL Display
Hello NXP Team,
I am looking for a solution to connect a 24 bit RGB display with a resolution of 480x272 and a pixel clock/DCLK of typ. 9 MHz (8-12 MHz) to the MIPI-DSI interface of the imx8mm.
I have 2 questions:
  1. Can you suggest a solution how I can connect the display to the MIPI-DSI interface (bridge/Converter and so on)?
  2. Do you know the minimum pixel clock that a MIPI-DSI interface can provide? Is it even possible to connect such a slow/small display to the MIPI-DSI-Interface?
Many thanks for your support!
Dirk
Re: imx8mm with 24-Bit RGB TTL Display
Hi @dirkbender!
At the moment we don't have any documentation or solution using a small display on iMX Processors.
We have an Application Note using the iMXRT 1170 with a small display using Mipi DSI protocol.
标记 (1)
无评分
版本历史
最后更新:
‎11-21-2025 04:31 PM
更新人:
