Hello NXP Community,
I'm currently using the i.MX93 EVK and have encountered an issue while monitoring the board's power supply with the BCU tool. Attached is a picture showing the voltage readings I'm getting. Despite these readings, everything else appears to be functioning normally—the Linux OS boots up without issues and the display output is as expected.
Has anyone else experienced similar voltage readings with their setup? Could this indicate a potential problem, or are these variations within a normal range? Any insights or suggestions on how to address this would be greatly appreciated.
Thank you in advance for your assistance!
Thank you very much !
Hi @Khaled_Gued!
Thank you for contacting NXP Support!
Looks like you are using the wrong command in BCU tool.
I am using the iMX93 EVK too and looks good.
the command that I have used is the next:
bcu monitor -board=imx93evk11b1
You can consult a detailed guidde here.
Best Regards!
Chavira
