The customer's engineer reported that there was a 1K resistance at the CTn of the acquisition pin about MC33774, see the picture. For example, if the external power supply is 3.3V, CTn-1 and CTn+1 are both 4V, but the voltage collected by CTn is only 1.7V. How does it affect the acquisition of CTn acquisition?Can the internal acquisition circuit be shared? Thanks!
Okay
I just want to confirm, that the board is your own design and you used our schematics. (what document did you use?) to make your board, but your board has an unusually resistance between the Cn and CTn-1
Please follow the link below:
https://www.nxp.com/products/MC33774
Scroll to Documentation, in this section you must choose "secure files", if you do not have access, you must open a ticket to request access.
I recommend you read:
I hope this information has helped you, please let me know if this information is enough, I have doubts if I am understanding you correctly.
Correct me if I'm wrong
Have a great day and best of luck.
Hi Louis
Before sharing my opinion I want to verify all the documentation.
What example or documentation is your design based on?
