2011473_en-US
2011473_en-US
2011473_en-US
S32K344-Memory configuration after HSE_B firmware usage feature flag is enabled
Hello:
I found in the section [32.3.1.2 Configuration details when the HSE_B firmware usage feature flag is enabled] in RM that the Reserved area, Application flash memory area, and Application data flash memory area have all been reduced. What data are stored in these areas after the HSE firmware is installed and used?
BestRegards,
Simon
Re: S32K344-Memory configuration after HSE_B firmware usage feature flag is enabled
You'll find out when you download HSE_B Firmware Reference Manual.
It is a secure file, so following procedure is needed to follow unless you have already done it before:
https://www.nxp.com/docs/en/user-guide/nxp-secure-access-rights-registration.pdf
For better understanding you may also see following link:
https://www.nxp.com/support/support/secure-access-rights:SEC-ACCESS
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-21-2025 12:36 PM
更新者:
