1996682_en-US
1996682_en-US
1996682_en-US
MPC5777C - M
Hello!
When I was reading the PFLASH chapter of the reference manual, I saw that the PFLASH_PFCR1 and PFLASH_PFCR2 registers have fields like P1_M2PFE. This field allows the user to enable or disable prefetching from specific masters.
My question is:
If the field P1_M2PFE is set to zero and the master with the logical ID number 2 (FEC) makes a read request, would the data be stored in the mini-cache before it is sent to the FEC or not?
My concern is that even disabling this field, a request from the associated master could evict data in the mini-cache that belongs to other master (e.g., a core).
Matheus
Re: MPC5777C - M
No, in your scenario there would be no difference between 'enabled' and 'disabled'.
Without pre-fetching master accesses directly the flash content, with pre-fetching it goes over mini-cache i.e. prefetch buffer.
As it is flash memory, no coherency issues happen.
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-21-2025 02:58 PM
更新者:
