Hello everyone,
I'm trying to use a SC18IS606 incombination with a BGT60UTR. Writing the registers seems to work. but when i try to read back the register values. the SC18IS606 puts a one in every 7e bit of a byte. On the logic analyzer I see the right values coming by. but reading them seems not to work properly.
I hope somebody can help.
Hi guoweisun,
Thanks for your reply, The problem was caused by my raspberry-pi. do not realy understand why but with a different processor the problem was solved.
regards
HI Danny:
Thanks for your interest in NXP Products.
You can see below read command format:
You can see above read command for instance.
Thanks!
