Hello.
I use S32K312 with AB SWAP HSE F/W, it is working well.
I need to SWAP A ↔ B patrition without running application.
Is it possible?
For example, other MCU give me script for TRACE32 like below.
Sean Sung
Hello @lukaszadrapa
Thank you for reply.
I'll try that.
Sean Sung
Hi @ssean
Take a look at this post:
https://community.nxp.com/t5/S32K/s32k3-flash-swap-requirements/m-p/1920123/highlight/true#M38475
I described there how to write minimalist code for AB swap. You can write very simple T32 script for this.
Lukas
