1985591_en-US
1985591_en-US
1985591_en-US
EB generated code: Marco use_Gpt_module of modules.h can not change to STD_ON
I added GPT, basenxp, platform, resource and other modules in EB, then after I generated code I found that Marco use_Gpt_module of modules.h can not change to STD_ON. How to change this marco to STD_ON?
Re: EB generated code: Marco use_Gpt_module of modules.h can not change to STD_ON
Sorry, this is a known bug and will be fixed in a future release.
If you want an immediate solution you will have to create a static version of the modules.h header file(remove all the generation code and just set directly to STD_ON or STD_OFF each of the USE_EXAMPLE_MODULE you are interested in).
Robin
回复: EB generated code: Marco use_Gpt_module of modules.h can not change to STD_ON
Here I use s32k344.
No ratings
Version history
Last update:
‎11-21-2025 03:32 PM
Updated by:
