1973334_en-US
1973334_en-US
1973334_en-US
EIM registers cannot be accessed
When I try to inject faults using EIM, whenever the code accesses the EIM register (read or write), it will enter BusFault. At the same time, when I use the Jtag simulator to observe, I find that EIM is not read, while other registers are OK. Is there any special operation required when accessing the EIM register? I checked RM and I think I meet these conditions. Why can't even the debugger see the register value?
Re: EIM registers cannot be accessed
The reason is simple. You do not have clocks enabled for EIM in your uC.
Please refer to the reference manual: chapter 46.1.5 Peripheral clock gating
Peter
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-21-2025 04:11 PM
更新者:
