1973172_en-US
1973172_en-US
1973172_en-US
S32K344 RTD5.0 trigger UsageFault when D_CACHE Enabled
Hi there,
I created a Uart project using RTD5.0, If D_CACHE is enabled, and called Lpuart_Uart_Ip_AsyncReceive() before send. It will trigger UsageFault.
If i undefined the D_CACHE_ENABLE Macro, It works fine.
or,
If i comment Lpuart_Uart_Ip_AsyncReceive() , the uart can send data normally, but can not receive any data now.
so, How should I solve this problem?
Thanks!
Here is my S32DS 3.5 with RTD 5.0 project.
回复: S32K344 RTD5.0 trigger UsageFault when D_CACHE Enabled
The root cause of this problem has been found. the thread stack is too small caused the context to be corrupted.
here is my project.
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-21-2025 04:11 PM
更新者:
