1968669_en-US
1968669_en-US
1968669_en-US
event occured timing is varies in eMIOS MCB mode
I use eMIOS UC23 as MCB mode.
CORE Clock : 100MHz
prescaler : all "1"
UC23 A register : 5000
I am checking flag interrupts with an oscilloscope, but the timing of event occurrences varies.
Please let me know if there are any possible causes for variation.
#s32k
Re: event occured timing is varies in eMIOS MCB modeThere was a problem with the core clock. I reviewed the clock settings and the problem was resolved.Re: event occured timing is varies in eMIOS MCB mode
Hi@Aren
Could you provide your demo project and test details, we will take the time to help you check it.
A note about variability
I want an event to occur every 50us, but the events occur at completely different times, such as 10us, 20us, etc.
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-21-2025 08:24 PM
更新者:
