MC33PT2000, During program execution, need to modify some data in DATARAM. While debugging, it was discovered that rewriting all 192 data to DATARAM was the only effective method. Is it possible to change a specific data in DATARAM Using a simple method? How can the code be written?
Dear Hongyu,
please use the PSC simulator. Please check the videos in this link. Please also check the section 8.1.2.2 in the PT2000 datasheet.
With Best Regards,
Jozef
Dear Hongyu,
the DataRAM access is described in the section 2.8 in the PT2000SWUG attached. Please refer to it.
With Best Regards,
Jozef
