We used the same PSC assembly code in the file(BASIC-FRDMPKPT2000EVM) with the PT2000 IDE to generate the PT2000_LoadData.c file, but it is different from the file in BASIC-FRDMPKPT2000EVM, as shown in the picture. user code:
Original:
The number of arrays is different. One is unsigned short PT2000_code_RAM1[105], another is
Is there an error in the document assembly code? Can you provide consistent code?
Thank you!
I didn't changed anything on BASIC-FRDMPKPT2000EVM Project. The download address:
The Original C code:
But,Both methods worked, so the issue is resolved. Thank you very much!
Hello Hongyu,
Where did get your BASIC-FRDMPKPT2000EVM Project? For PSC assembly code, we usually call it microcode.
Can you share your SW project here?
I think you have changed something on your BASIC-FRDMPKPT2000EVM Project but you didn't notice. Or you can generate a new BASIC-FRDMPKPT2000EVM Project as below way and try it again
And below is the Original RAMx section as your first page.
Hello Hongyu,
I have asked our application engineer who is in charge of the PT2000 to look into it. He is currently OoO, but will be back next week.
Thank you in advance for your patience.
BRs, Tomas
