Hello, its a bit difficult to understand the Simplified functional state diagram given in the datasheet of FS26 as somethings are not mentioned Detailly, is there any Documented or Video kind of thing where this is Explained detailly, if not Can someone Explain it in the Post.
Hello @JozefKozon ,
I have the Eval-Board RDK358BMU, and facing some issue with FS26 w.r.t Standby mode and wakeup.
could you please send me the same document ?
would also appriciate if you send me an example, considering Eval-Board RDK358BMU.
B.T.W , my company has already a valid NDA.
thanks in advance
Abdullah
@JozefKozon Please send me this file.
It has already been established that there is a valid NDA agreement.
Thank you.
Hi Djuric,
thank you for creating the case. I see it already in our inbox. We will support you via the case. For your company name, yes I have entered incorrect name. I have read your company name from your email address, but this is not correct one. In the case you created I see your company name in the description and for this, yes there is a valid NDA in our database.
With Best Regards,
Jozef
I opened a new ticket.
The only problem I can think of is that you entered the wrong name of the company I work for.
If you contact me by private message, I will send you the exact name of the company as well as the tag from the NDA contract.
This whole process is very slow and unnecessarily complex...
Dear Djuric,
I apologize for a late reply. I have checked our NDA database and unfortunately I couldn't find your company listed there. If the NDA was signed only recently, it is possible that it wasn't entered into our system yet. Please create a new case here and we will support you via the case.
I apologize for inconvenience and thank you for your understanding.
With Best Regards,
Jozef
@JozefKozon I would appreciate it if you could send me the same FS26 diagram you mentioned in the previous comment. The company I work for has a signed NDA agreement with NXP, which I also uploaded via the NXP website. Thank you.
@JozefKozon Can you send me the same document?
My company has a valid NDA agreement with NXP.
Thank you.
Hello @JozefKozon
Can you please send me this file as well, please?
Hi Jozef,
Yeah, Just gone through the Application Note, things are somewhat clear in this.
Thank you for the Document.
I am using FS26
Safety system basis chip with low power for ASIL D/ASIL B (ds616040-FS26) Datasheet, isn't it the same ?
Hi Naveen,
I have sent you an email.
With Best Regards,
Jozef
