1922980_en-US
1922980_en-US
1922980_en-US
S32K3XX MBD TOOL BOX PROJECT DEPLOYMENT ERROR
I'm trying to deploy  s32k3xx_dio_ebt.slx example code using S32K312 EVB .I'm facing issue while deploying the code in to the board .
Attaching the error i'm getting .
If anyone have any documents to refer for S32K3 model based example project please let me know .
Re: S32K3XX MBD TOOL BOX PROJECT DEPLOYMENT ERROR
Hi, @reshma97 ,
Thank you for your interest into Model-Based Design Toolbox for S32K3.
The error in the attached image generally occurs when the connection with the board is not correctly established. Check again the USB connection cable of the board and the power cable, or you can try with another USB cable.
To understand the method you used, I wanted to know how you tried to deploy: building the model in Simulink or to directly download the .elf file next to the model on the board?
Let us know if you problem persists.
Dragos
No ratings
Version history
Last update:
‎11-21-2025 09:17 PM
Updated by:
