1919939_en-US
1919939_en-US
1919939_en-US
i.mx RT1160 powerup sequence
In my design R=100k and C=1uF as I have unknown delay time in VDD_HIGH_IN and DCDC_IN and 1ms for DCDC_PSWITCH is not enough. so I increased the RC delay time. What will happen if DCDC_Pswitch delay is larger than 1ms.
Re: i.mx RT1160 powerup sequence
Hi @Swezin ,
This might still be related with the delay for DCDC_PSWITCH, you know, if the delay is not enough to bring up the DCDC internally, only a manual reset can not reset the device. Please extend the delay and try again.
BTW, if the problem is still there, please submit a private ticket with the whole schematics for a review, it is hard to locate the root cause with part of the schematics. To submit a private ticket, please kindly refer to https://www.nxp.com/video/tutorial-for-nxp-support-case-portal:NCP-VIDEO .
Kan
Hi @Kan_Li
Thanks for your fast response. Another question.
The reset is not functioning. I measured the voltage, and it drops to zero when I press the switch, but the chip does not reset.
Thank you Kan for your quick reply. Another question,
Hi @Swezin ,
No issue would happen if you extend the delay for DCDC_Pswitch.
Kan
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-21-2025 12:50 PM
更新者:
