1911727_en-US
1911727_en-US
1911727_en-US
[S32K3XX] C40_Ip using for accessing Code flash memory patition
Hi.
I am developing flash access using C40_Ip api in bootloader.
Data memory partition(0x10000000) can be accessed by that API.
But code memory partition(0x500000 ~ 0x007FE000) can not be accessed.
Hard fault assert is happened.
C40_Ip API is located in SRAM like below.
Could you give me some guide or hint for this debugging?
Thank you in advance.
Re: [S32K3XX] C40_Ip using for accessing Code flash memory patitionYes.
It's work normally
Hi@Changhawn
Is your problem solved?
I see that you have already set your answer as a solution.
Basic working is confirmed.
My access region is not wrong.
I encountered the same problem as you. When writing to the PFLASH, a hardware fault occurred. Could you please tell me how you solved it?
No ratings
Version history
Last update:
‎11-24-2025 07:17 AM
Updated by:
