1908196_en-US
1908196_en-US
1908196_en-US
pfe slave test steps based on BSP41
Recently, I tested pfe master/slave feature, but it seems the test steps have changed, but I did not find related description documents in pfeng repo or the firmware docs.
Would you please help to check the issue and give the steps how to test pfe master/slave feature and where I can get them?
Zhantao
Re: pfe slave test steps based on BSP41
We apologize for the delay from our side.
We have received the following update:
Customer could download the "PFE_S32G_A53_LNX_UserManual.pdf" from the page of S32G BSP download, for example:
After download “PFE-DRV_S32G_A53_LNX_1.7.0_DOC.zip” and extract it, then you will get the
"PFE_S32G_A53_LNX_UserManual.pdf".
Please, let us know.
Thanks for your feedback. It does seem to be that the latest user manual was published under v1.5.0.
We will confirm with the related team the reason for this and if it is available at this moment.
We apologize for any delay from our side.
Hi @Daniel-Aguirre,
I used RDB3 v1.1 SOC for test, and I followed the steps in section "2.5.5 Runtime" of doc: "PFE_S32G_A53_LNX_UserManual.pdf", which is from the previous pfe branch, like v1.4.0, but now these .pdf files are all removed from the v1.7.0 branch.
So I don't know where can get the new steps for pfe master/slave mode.
Zhantao
Can you let us know which documents you have read? Also, which steps are you following?
Can you let us know which S32G variant you are using?
No ratings
Version history
Last update:
‎11-21-2025 04:43 PM
Updated by:
