1890483_en-US
1890483_en-US
1890483_en-US
iMXRT117x: Linking errors during build smart_lock app for SLN-VIZN3D-IOTDG board
We have a customer is trying to build the smart-lock application for SLN-VIZN3D-IOTDG board. They followed the instructions in the reference manual:
SLN-VIZN3D-IOT SW Developer Guide (nxp.com)
When building the smart_lock main application, they get the following errors:
What is the resolutions for the above errors, Here are some old tickets related to same issue:
How to solve gcc linker error (.ARM.exidx+0x0): relocation truncated to fit: R_ARM_PREL31: followup ...
Re: RT1064: How to solve gcc linker error (.ARM.exidx+0x0): relocation truncated to fit: R_ARM_PREL3...
Thanks.
Ayman Sydhom
Re: iMXRT117x: Linking errors during build smart_lock app for SLN-VIZN3D-IOTDG board
Hi Kerry,
The customer confirmed that the app builds fine after downgraded the MCUXpresso.
Thanks.
Ayman
Hi @asydhom ,
  You are welcome!
  I already test both two IDE versions, so, I am sure of this solution.
   Yes, after your end customer also make it works, please help me to mark the correct answer, just to close this case, thanks.
Any new issues, welcome to create the new case.
kerry
Thanks Kerry. Will communicate the resolution to our customer and let you know if this solved the issue or not.
Regards.
Ayman
Hi @asydhom ,
  Thank you for your interest in the NXP MIMXRT product, I would like to provide service for you.
I know your failed issues reason, your used IDE version is high, as I also test it on my side, my MCUXpresso IDE is the v11.9.0, then same build result to you.
  So, I download the older MCUXPresso IDE Version to : V11.4.1, as the get start also mentioned:
You can download it from this linker:
https://www.nxp.com/design/design-center/software/development-software/mcuxpresso-software-and-tools...
Download the previous version:
Then, you need to download the SLN-VIZN3D-IOT SDK
https://mcuxpresso.nxp.com/en/builder?hw=SLN-VIZN3D-IOT
You need to add it to the MCUXPresso IDE
Now, build your project again, you will find it is OK to use:
Please try my method on your side.
If your question is solved, please help me to mark the correct answer, just to close this case, thanks.
Kerry
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-21-2025 04:53 PM
更新者:
