1883457_en-US
1883457_en-US
1883457_en-US
Writing to Flash memory kills MCU
Hello! I am trying to save a variable, which a user input, to the flash memory. I am using MC56F82... and the IFsh1 library. I disable the events and then erase the block and then write to the flash, but my MCU keeps dying, i have to restart it and flash it again to get it working. Any ideas on how to do it correctly?
Re: Writing to Flash memory kills MCU
Thank you for the help!
I attach the code here.
XiangJun Rong
This is the flash example code based on CodeWarrior for DSP56800E ver8.x.
Pls refer to it.
Regarding your question, the flash erasing/programming code must be located in flash and copied to p RAM, you have to run the erasing/programming code in  RAM to manipulate the flash.
Hope it can help you
XiangJun Rong
up
标记 (1)
无评分
版本历史
最后更新:
‎11-21-2025 05:00 PM
更新人:
