1876434_en-US
1876434_en-US
1876434_en-US
RT117x: reset all peripherals but not the core
At particular times, in my FW I would need to reset all the peripherals but not the core. Actually I would need to get back to the state it is in as soon as the rom bootloader yields control to our FW and jumps to ResetISR (so some peripherals have to work, e.g. FlexSPI).
Of course, I also have to disable the NVIC interrupts, but for that I was thinking of doing it with a for loop (but tell me if there is a better way)
do you have any suggestions?
best regards
Max
Re: RT117x: reset all peripherals but not the core
Hi @mastupristi,
I'm afraid there isn't a straightforward way of doing this. You would have to manually de-initialize all of the modules, which implies that ideally you already know exactly what modules were initialized in the first place. Is there a particular reason why doing a SW reset would not be compatible with what you are looking for?
BR,
Edwin.
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-21-2025 10:04 PM
更新者:
