1857516_en-US
1857516_en-US
1857516_en-US
MIMXRT1060-EVKB + AUD-EXP-42448 Left-Right Channel swap when in Mono
I configured an audio loopback from my soundcard, into the CS42448 ADC, using the SAI eDMA driver with a ping-pong buffer strategy, back into the CS42448 DAC and into my soundcard again.
I am using I2S mode with Left and Right channels.
When using the kSAI_Stereo mode, channels come back in the expected order, but either kSAI_MonoLeft or kSAI_MonoRight swaps the channels.
Is this a known issue?
i.MXRT 106xRe: MIMXRT1060-EVKB + AUD-EXP-42448 Left-Right Channel swap when in Mono
Thanks for your reply, @EdwinHz.
Yes, I agree it is easy enough to just pick kSAI_MonoRight instead of kSAI_MonoLeft upon initializing the I2S interface.
Please note that I am not sure whether this applies only to I2S mode (out of TDM, left/right justified, etc).
Either way, this post might help other people encountering the same behavior.
Vasco.
Hi @vascofsantos,
This channel swap should not cause many issues as the channels are already in Mono. However, I don't think it is an indented behavior, so I will definitely report this internally for their deliberation. Thank you for reporting this.
BR,
Edwin.
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-21-2025 10:31 PM
更新者:
