During the development of S32K312 FLEXCAN, I need to configure TDC for delay compensation, but I did not find the relevant option in the FLEXCAN module peripherals of the S32DS graphical configuration interface, as shown below
Which interfaces or peripherals should be called to configure TDC?
yes, this is not in component setting. You can use available API before you put module to normal mode. For Example...
BR, Petr
