We am using i.mx9352 A1 model.
we are unable to port the BSP file due to some error is coming as given below
Success 0 Failure 1
1:2 1/ 1 [HID(W):LIBUSB_ERROR_PIPE ] SDPS: boot -f imx-boot-imx93evk-sd.bin-flash_singleboot
Could you provide solution for that error
Vivek
Hi @Binh_Hoang
Kindly check the voltage as per Table 29 of NXP hardware design guide and check the VDD_SOC_0V8 at SOC end.
Hi @vivek5676,
I'm facing the same issue. Could you please let me know which change is needed for this case? Please give me more details.
Thank you in advance,
Binh
My problem get resolved after changes done in hardware.
