Hi NXP team,
In the datasheet, the MCU i.MX RT1176 supports MMC up to version 5.0.
However, it is easier to find memories with versions 5.1 and upwards.
My question is: Will the MCU function with memories supporting versions 5.1 and upwards but the MCU will not support the functionalities for versions 5.1 and upwards?
Br // PuiYee
Hi @puiyee_poon ,
I have purchased one samsung emmc 5.1 previously, and I have tested it on the RT1176, no matter the directly communication or the code boot from emmc, it works OK.
So, at least the emmc5.1 works, to the up version, you may need to test it on your side.
Wish it helps you!
Kerry
