1851422_en-US
1851422_en-US
1851422_en-US
about S32K3XX RTOS example
i'm tried to executed the RTPS_example_S32K312_SC1/RTOS_example_S32K312_SC1
I DID EB tresos.exe and install new software Added a file whose file name ends with updatestie.
generate the new project and then build project
but i meet the error be called the file Os.h not in this proejct. and in peripherals RTOS_S32K3XX is not found in the toolcahin/IDE project. the project will not compile!
what can i do to solve the error?
Re: about S32K3XX RTOS example
i figure out i missed to download s32m27X RTM in freeRTOS 10.6.0.
Thank  you.
Seems that you are testing the example of S32K3xx_NXP_RTOS_version_0.4.1
Maturity level is CD. This is CD NXP RTOS 0.4.1 release for S32K3xx platform to support AUTOSAR OS version 4.4 validated on real hardware.
Did you follow the method introduced in chapter 1.2.1 Installation Design Studio of S32K3xx_NXP_RTOS_4_4_153_CODEDROP_0_4_1_D2312_Readme.pdf?
Robin
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-21-2025 03:53 PM
更新者:
