1848856_en-US
1848856_en-US
1848856_en-US
HTRC110 PSK/FSK tag reading Capabilities
I need to use HTRC110 to read FSK/PSK modulated tokens (mainly HID MicroProx), I found out that the chip is incapable of dealing with such modulation, any confirmation and explanation as to why? such modulation should be simple to handle. Any other alternative from NXP?
Re: HTRC110 PSK/FSK tag reading CapabilitiesGood afternoon alasa995! I'm also doing this research. How far have you gotten? Best regards, Sergey.Re: HTRC110 PSK/FSK tag reading Capabilities
Hi, I managed to make the chip work to decode FSK modulation, all that was needed was to tweak the config for the IC.
タグ(1)
評価なし
バージョン履歴
最終更新日:
木曜日
更新者:
