1848645_en-US
1848645_en-US
1848645_en-US
How to Enable and Disable Packet Forwarding Engine (PFE) at Runtime in Linux
Hello;
I am seeking a method to deactivate/partially disable /constrain/disable power the PFE in runtime.
Re: How to Enable and Disable Packet Forwarding Engine (PFE) at Runtime in Linux
Hello, @irfank
Thanks for the questions
Sorry that I am not sure which version BSP you are using nor which device referred to(S32G2 or G3?), let me take S32G2RDB2 with BSP40 for example.
Currently, the PM runtime feature is enabled by default in PFE Linux driver.
By default, the device PM control policy is “auto”, which means to allow the device to be power managed at run time. If you want to disable the run time PM, you may change it to “on”, which to prevent the device from being power managed, logs below for your reference.
root@s32g274ardb2:~# cat /sys/devices/platform/soc/46000000.pfe/power/control
auto
root@s32g274ardb2:~# echo "on" > /sys/devices/platform/soc/46000000.pfe/power/control
on
Best Regards
Chenyin
No ratings
Version history
Last update:
‎11-21-2025 04:06 PM
Updated by:
