Hi Nxp partner
After we perform the calibration process for PTB ,we get the offset step is 7271 and gainstep is 1.
The range of Offset compensation is only -128~127. Offset step is 7271 is bigger than 127.
We cannot write 7271 to Offset compensation (offset ch ).
Can we first set offset compensation(offset ch ) to zero and then
add ptb offset compensation formula (see the attached file. before sending ptb
measurement value .
Br,
Mike Liang
Please refer to MM9Z1_638_calibration_v2.xlsx (attached) for details on the calculation.
Hope this helps.
